- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Excluded Middle for Type?
- Date: Tue, 2 Jul 2013 16:07:47 -0400
Thanks Jonas and Viktor! It seems both of you reached the answer
"consistent, so long as Set remains predicative" very quickly. This
is very helpful.
--Chris
On Tue, Jul 2, 2013 at 4:00 PM, Jonas Kaiser
<jonas.kaiser.it AT gmail.com>
wrote:
> Hi,
> first of all, sorry for not sending this to the whole list at first.
> Secondly I believe that
> dit : forall T: Type, T + T -> False
> is equivalent to XM and AC.
> The 'dit' stands for decidable inhabitance of types in the sense of for each
> type you can obtain either a member or a proof that no such member exists
> (whether one should still call this deciding is of course debatable)
> ragards
> Jonas
> ---------- Forwarded message ----------
> From: Jonas Kaiser
> Date: 2 July 2013 21:52
> To: Chris Casinghino
> <chris.casinghino AT gmail.com>
> Hi Chris,
> afaik it follwos from assuming EM for Prop and the Axiom of Choice (in the
> sense of the Epsilon Library)
> cheers
> Jonas
> On 2 July 2013 21:44, Chris Casinghino
> wrote:
>> Hi Adam,
>> Thanks for the quick response. You're certainly right, and I should
>> have been a little clearer. I'm interested specifically in logical
>> consistency, and am not concerned about extraction or the fact that
>> the axiom will get in the way of reduction.
>> --Chris
>> > Such an axiom certainly breaks extraction, since it has no natural
>> > computational interpretation, but perhaps you don't care about
>> > extraction.
>> > It also makes Gallina "computation" highly non-computational, which also
>> > might not bother you, depending on the application. I don't know if
>> > it's
>> > logically consistent.
> Jonas Kaiser
> Saarbrücken
> Jonas Kaiser
> Saarbrücken
- [Coq-Club] Excluded Middle for Type?, Chris Casinghino, 07/02/2013
- Re: [Coq-Club] Excluded Middle for Type?, Adam Chlipala, 07/02/2013
- Re: [Coq-Club] Excluded Middle for Type?, Chris Casinghino, 07/02/2013
- Re: [Coq-Club] Excluded Middle for Type?, Viktor Vafeiadis, 07/02/2013
- Message not available
- Fwd: [Coq-Club] Excluded Middle for Type?, Jonas Kaiser, 07/02/2013
- Re: [Coq-Club] Excluded Middle for Type?, Andrew Cave, 07/02/2013
