- To: Chris Casinghino <chris.casinghino AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Excluded Middle for Type?
- Date: Tue, 2 Jul 2013 16:48:30 -0400
Also you may want to note that it's inconsistent if you happen to be
using -impredicative-set for some reason.
This is explained in part 2.5 of
http://coq.inria.fr/stdlib/Coq.Logic.ClassicalFacts.html
On Tue, Jul 2, 2013 at 3:38 PM, Chris Casinghino
wrote:
> Hi all,
> I notice that, where the Coq FAQ discusses safe axioms, it mentions
> excluded middle only for "Prop". This also seems to be the case in
> the standard libraries.
> Would it also be safe to add excluded middle for "Type"? That is,
> could I add the following?
> Inductive sum (A B : Type) : Type :=
> | leftT : A -> sum A B
> | rightT : B -> sum A B.
> Axiom em_type : forall A : Type, sum A (A -> False).
> Thanks!
> --Chris Casinghino
- [Coq-Club] Excluded Middle for Type?, Chris Casinghino, 07/02/2013
- Re: [Coq-Club] Excluded Middle for Type?, Adam Chlipala, 07/02/2013
- Re: [Coq-Club] Excluded Middle for Type?, Chris Casinghino, 07/02/2013
- Re: [Coq-Club] Excluded Middle for Type?, Viktor Vafeiadis, 07/02/2013
- Message not available
- Fwd: [Coq-Club] Excluded Middle for Type?, Jonas Kaiser, 07/02/2013
- Re: [Coq-Club] Excluded Middle for Type?, Andrew Cave, 07/02/2013
