coq-club - Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin
  • Date: Fri, 05 Jul 2013 09:39:42 +0200
With -emacs, you have to interpret Coq's output to determine whether it is good or bad, though, which -ideslave seems to do for you.
Also, apart from the newline (which is also not sent in -emacs), the synchronization of -ideslave seems a lot saner than -emacs: in the latter, it is possible to accidentally send half a phrase, which seems impossible in -ideslave. In emacs, the following is possible:
| <prompt>Coq < 1 || 0 < </prompt> Foo [press return]
| [Wait, because Coq expects a terminator]
In -ideslave, this is:
| <call val="interp">Foo</call>
| <value val="fail" loc_s="3" loc_e="4">
| Syntax error: &apos;.&apos; or &apos;...&apos; expected after | [tactic:tactic] (in [proof_mode:subgoal_command]).</value>
So you will get an error (with usable feedback) no matter how much you mangle the sent commands.
Based on Pierre's examples, I am not sure how you obtain feedback on 'state' in the -ideslave mode (I see a 'rewind' command that undoes a command, but do you have to synchronize this in your own IDE somehow? Especially since Coq's rewind can step back farther than instructed).
Carst
On 07/04/2013 11:50 PM, Benjamin Berman wrote:
Try "coqtop -emacs". You might also consider redirecting stderr to
stdout (redirectErrorStream in the java.lang.ProcessBuilder)
--Ben
On Thu, Jul 4, 2013 at 4:40 PM, t x
<txrev319 AT gmail.com
<mailto:txrev319 AT gmail.com>>
wrote:
Along this line: what is the easiest way to parase output from
coqtop -ideslave? I know that I can set notation off -- however, is
it possible to get back an lisp sexp or an xml abstract syntax tree?
(I don't care about human readability; I can convert it from machine
readable to human readable in my client code.)
On Thu, Jul 4, 2013 at 2:37 PM, t x
wrote:
https://github.com/vim-scripts/CoqIDE/blob/master/plugin/coq_IDE.vim#L111-L119
is the most concise description of the "coqtop -ideslave"
interface I know of.
One tip: coq does not seem to send back "\n", so when reading
back from Coq, care needs to be taken care of to avoid hanging
with Java IO routines. (I spent days troubleshooting this.)
On Thu, Jul 4, 2013 at 9:35 AM, Pierre Boutillier
<pierre.boutillier AT pps.univ-paris-diderot.fr
<mailto:pierre.boutillier AT pps.univ-paris-diderot.fr>>
wrote:
Hi,
There is no documentation. Pieces of information have to be
extracted from /branches/v8.4/toplevel/ide_intf.ml
<http://ide_intf.ml> or /trunk/lib/serialize.ml
<http://serialize.ml>
In an hurry :
- start coqtop with the option -ideslave
- then speak in xml.
you can only send "<call val="foo"></call>" where foo is
"interp" a coq sentence "about", "quit", "search" a coq
regexp, etc
coqtop answers a list <message></message> (always empty in
v8.4) and then a "<value val="good"(or "fail")></value>"
"<call val="interp" verbose="" raw="">a coq
sentence.</call>" is universal but you want more structured
answers than only string. Therefore, please ask coqdev to
add the missing primitives you need ...
here is a log of a toy interaction :
eduroam-prg-sg-1-44-231:~ pirbo$
/Applications/CoqIdE_8.4pl2.app/Contents/Resources/bin/coqtop
-ideslave
<call val="interp">Print nat.</call>
<value val="good"><string>Warning: query commands should not
be inserted in scripts
Inductive nat : Set := O : nat | S : nat -&gt; nat
For S: Argument scope is [nat_scope]
</string></value>
<call val="interp">intuition.</call>
<value val="fail">
Error: Unknown command of the non proof-editing mode.</value>
<call val="about"/>
<value
val="good"><coq_info><string>8.4pl2</string><string>20120710</string><string>May
2013</string><string>May 15 2013
18:00:03</string></coq_info></value>
<call val="interp">Definition bar := I.</call>
<value val="good"><string></string></value>
<call val="rewind" steps="1"/>
<value val="good"><int>0</int></value>
<call val="interp">Goal False.</call>
<value val="good"><string></string></value><goal/>
<value val="fail">Incorrect query.</value>
<call val="goal"/>
<value val="good"><option
val="some"><goals><list><goal><string>1</string><list/><string>False</string></goal></list><list/></goals></option></value>
<call val="quit"/>
<value val="good"><unit/></value>eduroam-prg-sg-1-44-231:~
pirbo$
All the best,
Pierre B.
Le 4 juil. 2013 à 17:17, Valentin Robert
<valentin.robert.42 AT gmail.com
<mailto:valentin.robert.42 AT gmail.com>>
a écrit :
> Hello,
> I cannot provide good answers to your questions, but some
people recently wrote a vim plugin for using Coq. Their
development is available on github. I suggest looking at
this file in particular:
https://github.com/trefis/coquille/blob/pathogen-bundle/autoload/coquille.py
> It might give you some insight.
> Best luck,
> - Valentin
> On Thu, Jul 4, 2013 at 4:10 PM, Abhishek Anand
<abhishek.anand.iitg AT gmail.com
<mailto:abhishek.anand.iitg AT gmail.com>>
wrote:
> Hi,
> I'm trying to develop a Coq plugin for my fav.
IDE(https://netbeans.org/) as a hobby project.
> The plugin needs programmatically talk to coqtop.
> Is there some description of a "protocol" one should
follow while
> programmatically talking to coqtop?
> So far, I did some reverse engineering and found out:
> (please correct me if I am wrong)
> 1) Coqtop prints "coq<" on stderr when ready to accept an
input. I guess I need to wait until prints "coq < " on
stderr before writing to coq's inputstream.
> 2) If coqtop didn't like the previous command, the last
line is of the form "error ...".
> So, while sending the contents of user's editor window
to coqtop, I need to stop as soon
> as I encounter one of these and prompt the user about
the error.
> I need more information so that I can reliably parse
coqtop's output, especially proof state and present them to
the user in a more intuitive way. I can try to reverse
engineering most of these, but would appreciate if some
description of a protocol that coqtop follows is available
somewhere.
> Some brief description of how CoqIDE works might also be
useful.
> Thanks,
> -- Abhishek
> https://github.com/aa755/nbcoq
