Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin
- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin
- Date: Fri, 05 Jul 2013 11:46:38 +0200
On 05/07/2013 09:39, Carst Tankink wrote:
> Based on Pierre's examples, I am not sure how you obtain feedback on
> 'state' in the -ideslave mode (I see a 'rewind' command that undoes a
> command, but do you have to synchronize this in your own IDE somehow?
> Especially since Coq's rewind can step back farther than instructed).
IDE have to do some work, rewind documentation is :
(** Backtracking by a certain number of (non-state-preserving) commands.
This is used by Coqide.
It may actually undo more commands than asked : for instance instead
of jumping back in the middle of a finished proof, we jump back before
this proof. The number of extra backtracked command is returned at
the end. *)
Otherwise,
YES specification has to be made
YES a concrete syntax tree is much better than a string
YES it has to be adapted to asynchronous communication
YES ...
experimental attempts to do that are spread over the github forest. Time
has to be found to complete these tasks ...
Pierre B.
- [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Abhishek Anand, 07/04/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Beta Ziliani, 07/04/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Valentin Robert, 07/04/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Pierre Boutillier, 07/04/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, t x, 07/04/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Benjamin Berman, 07/04/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Carst Tankink, 07/05/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Pierre Boutillier, 07/05/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Pierre Courtieu, 07/08/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Abhishek Anand, 07/23/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Thomas Refis, 07/23/2013
- Re: [Coq-Club] help w/ coqtop programmatic interaction for Netbeans plugin, Pierre Boutillier, 07/24/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, t x, 07/05/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Abhishek Anand, 07/06/2013
