- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] help w/ coqtop programmatic interaction for Netbeans plugin
- Date: Wed, 24 Jul 2013 08:34:24 +0200
2 days ago I answered :
Le 19 juil. 2013 à 01:07, t x <txrev319 AT gmail.com> a écrit :Hi,it sends <call id="-2" val="interp" raw="">Set Printing Implicit.</call>
I'm wondering if there's a solution to this (besides "use proof general" :-) )
I'm using Coq inside of Vim, which is running coq via "coqtop.opt -ideslave"
In trying to debug one of my tactics, I want to execute:
"Set Printing Implicit."
Unfortunately, I get back the response
"Use CoqIDE display menu instead."
Thus, I'm wondering:
1) Does the CoqIDE display menu send a different message to "coqtop.opt -ideslave"?
2) And if so, how can I mimic this message?you should add the 'raw=""' in your call :-)
Cheers,
Thanks!
Pierre B.
Le 23 juil. 2013 à 23:13, Abhishek Anand <abhishek.anand.iitg AT gmail.com> a écrit :
Thanks for that example.When I send "Set Printing Universes." or other set command , (coqtop -ideslave) replies back :<?xml version="1.0"?><value val="fail" loc_s="0" loc_e="23">Error: Use CoqIDE display menu instead</value>How do I get around this?ThanksOn Tue, Jul 23, 2013 at 2:17 AM, Thomas Refis <thomas.refis AT gmail.com> wrote:
2013/7/23 Abhishek Anand <abhishek.anand.iitg AT gmail.com>:
> I think I know that I'm doing something wrong. when I process the line +Precisely.
> Case "->"; auto. ,
> I need to send it to CoqTop in 2 steps. First send "+ " and then "Case "->";
> auto."
Note that you get the same behavior when you send something after a
dot (i.e. it is ignored), see http://paste.awesom.eu/IFp .
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, (continued)
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, t x, 07/04/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Benjamin Berman, 07/04/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Carst Tankink, 07/05/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Pierre Boutillier, 07/05/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Pierre Courtieu, 07/08/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Abhishek Anand, 07/23/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Thomas Refis, 07/23/2013
- Re: [Coq-Club] help w/ coqtop programmatic interaction for Netbeans plugin, Pierre Boutillier, 07/24/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, t x, 07/05/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Abhishek Anand, 07/06/2013
- Re: [Coq-Club] Fwd: help w/ coqtop programmatic interaction for Netbeans plugin, Makarius, 07/08/2013
