[Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?
- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?
- Date: Sun, 14 Jul 2013 13:59:30 +0200
Hi all!
Let's take the following inductive type (simplified example):
Inductive Op :=
| add (_:nat) : Op
| remove : Op
| replace (_:nat) : Op.
I want to write a partial function which can take only an 'add' or
'replace' operation and returns a value of type T. I've found (at
least) three ways of specifying it:
Definition do_stuff (a: Op) : T + { a = remove }.
... Defined.
Definition do_stuff' (a: Op) : (a <> remove) -> T.
... Defined.
Definition do_stuff'' (a: {o: Op | o <> remove}) : T.
... Defined.
I believe all three are equivalent. Do you agree?
I'm trying to decide which to go ahead with. In your experience, what
are the advantages and disadvantages of each of these choices in
practice? Which do you prefer?
Thanks!
www.mhelvens.net
- [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?, Michiel Helvensteijn, 07/14/2013
- Re: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?, Pierre-Marie Pédrot, 07/14/2013
- Re: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?, Michiel Helvensteijn, 07/14/2013
- Re: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?, Arnaud Spiwack, 07/15/2013
- Re: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?, Michiel Helvensteijn, 07/16/2013
- Re: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?, Arnaud Spiwack, 07/16/2013
- Re: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?, Hendrik Tews, 07/16/2013
- Re: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?, Hendrik Tews, 07/17/2013
- Re: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?, Michiel Helvensteijn, 07/17/2013
