coq-club - Re: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?
  • Date: Wed, 17 Jul 2013 09:42:23 +0200
Michiel Helvensteijn
<mhelvens AT gmail.com>
writes:
Thanks! You do make the sumor idiom seem very attractive. :-)
Well, I should have added to my summary, that the sumor idiom may
become a nuisance in expressing properties. I did not elaborate
on that, because it is mostly obvious. With sumor, your function
does not easily compose any more and therefore many of your
theorems need a case distinction.
For instance, in http://askra.de/science/coalgebraic-cut I use a
partial nth function
Fixpoint nth(l : list A)(n : nat)(inside : n < length l) : A
and the file lists.v contains many results about this nth. There
are only 5 generalize's (which I recently reduced to 2 using some
more clever lemma). With the sumor idiom, many of the theorems
would look much more ugly, because of the case distinction. With
sumor, properties such as
forall(f : A -> B)(l : list A)(n : nat)(n_less : n < length (map f l)),
nth (map f l) n n_less_map = f (nth l n (nth_map_tcc f l n n_less))
become quite complicated (here, nth_map_tcc constructs a prove
for "n < length l" from n_less). Using a case distinction in this
property might make it unsuitable for rewriting.
Bye,
Hendrik
