coq-club - Re: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?
  • To: Hendrik Tews <tews AT os.inf.tu-dresden.de>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Subtype argument, precondition or sumor return type? Which to choose?
  • Date: Wed, 17 Jul 2013 10:53:41 +0200
On Wed, Jul 17, 2013 at 9:42 AM, Hendrik Tews
wrote:
> Thanks! You do make the sumor idiom seem very attractive. :-)
> Well, I should have added to my summary, that the sumor idiom may
> become a nuisance in expressing properties. I did not elaborate
> on that, because it is mostly obvious. With sumor, your function
> does not easily compose any more and therefore many of your
> theorems need a case distinction.
Yes, I understand.
I'm trying something new now. I develop the subtype version `st`. Then
I also implement the sumor version `so`, in terms of `st`, and prove a
companion lemma about the output of `so`:
Definition st (a: {o: Op | o <> remove}) : nat := 42.
Program Definition so (a: Op) : nat + {a = remove} :=
match a with
| remove => inright eq_refl
| _ => inleft (st a)
end.
Solve All Obligations using (congruence || discriminate).
Lemma so_st: forall a, (a = remove) -> (exists P, so a = inright P).
intros a H; destruct a;
(contradict H; discriminate) || (unfold so; eauto with *).
Qed.
The idea is that I can choose which to go with on a case by case
basis. Not sure yet if it works in practice.
www.mhelvens.net
