- From: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
- To: Pierre Casteran <pierre.casteran AT labri.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Fixpoint definition
- Date: Mon, 15 Jul 2013 22:00:23 +0200 (CEST)
Hi,
Sorry, I modified my code without checking it. I indeed wanted to call
recursively test2:
Fixpoint test2 p :=
match p with
| (_, Nil) => 0
| (_, Cons l) =>
test2 l
end.
What is really strange for me is that the recursion is /trivially/
structurally decreasing.
JH
----- Mail original -----
> De: "Pierre Casteran"
> À: "Jacques-Henri Jourdan"
> Cc:
> Envoyé: Lundi 15 Juillet 2013 17:33:01
> Objet: Re: [Coq-Club] Fixpoint definition
> Hi Jacques-Henri,
> > However, the termination checker fails on this similar test case:
> > Fixpoint test2 p :=
> > match p with
> > | (_, Nil) => 0
> > | (_, Cons l) =>
> > test l
> > end.
> This is not the termination checker that fails, but the type checker
> Your test2 should take as argument a pair (the type of the first
> component is
> left unspecified, but cartesian product are not recursive types.
> The closest solution I think about should be:
> Definition test2 (p: nat * lst) :=
> match p with
> | (_, Nil) => 0
> | (_, (Cons l as l')) =>
> test l'
> end.
> Is this what you meant ?
> Pierre
> > Do you have any idea why ? Is there a common workaround (other than
> > using the other formulation above, that would lead to a lot of code
> > duplication in my case) ?
> > Thanks,
- [Coq-Club] Fixpoint definition, Jacques-Henri Jourdan, 07/15/2013
- Re: [Coq-Club] Fixpoint definition, Pierre Casteran, 07/15/2013
- Re: [Coq-Club] Fixpoint definition, Michiel Helvensteijn, 07/15/2013
- Re: [Coq-Club] Fixpoint definition, Jacques-Henri Jourdan, 07/15/2013
- Re: [Coq-Club] Fixpoint definition, Jacques-Henri Jourdan, 07/16/2013
- Re: [Coq-Club] Fixpoint definition, Daniel Schepler, 07/16/2013
