- To: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
- Cc: Pierre Casteran <pierre.casteran AT labri.fr>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Fixpoint definition
- Date: Mon, 15 Jul 2013 22:37:22 +0200
On Mon, Jul 15, 2013 at 10:16 PM, Jacques-Henri Jourdan
wrote:
>> But it's structurally decreasing through both `lst` and `pair`, and
>> basic `Fixpoint` only understands *really trivial* structural
>> decreasing arguments.
> Well, but it does works when it is through pair then lst, but not through
> lst then pair, which is really confusing.
As I understand it, your first example works because it structurally
decreases on a `lst` parameter. A `lst` can "contain itself" by
definition.
Your second example tries to decrease on a `pair`. As far as the type
`pair` is concerned, the actual parameter is not structurally smaller
than the formal parameter, it's just different.
www.mhelvens.net
- [Coq-Club] Fixpoint definition, Jacques-Henri Jourdan, 07/15/2013
- Re: [Coq-Club] Fixpoint definition, Pierre Casteran, 07/15/2013
- Re: [Coq-Club] Fixpoint definition, Michiel Helvensteijn, 07/15/2013
- Re: [Coq-Club] Fixpoint definition, Jacques-Henri Jourdan, 07/15/2013
- Re: [Coq-Club] Fixpoint definition, Jacques-Henri Jourdan, 07/16/2013
- Re: [Coq-Club] Fixpoint definition, Daniel Schepler, 07/16/2013
