- From: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
- To: Michiel Helvensteijn <mhelvens AT gmail.com>
- Cc: Pierre Casteran <pierre.casteran AT labri.fr>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Fixpoint definition
- Date: Tue, 16 Jul 2013 11:19:24 +0200 (CEST)
----- Mail original -----
> De: "Michiel Helvensteijn"
> À: "Jacques-Henri Jourdan"
> Cc: "Pierre Casteran"
> "coq-club"
> Envoyé: Lundi 15 Juillet 2013 22:40:59
> Objet: Re: [Coq-Club] Fixpoint definition
> On Mon, Jul 15, 2013 at 10:37 PM, Michiel Helvensteijn
> wrote:
> >> Well, but it does works when it is through pair then lst, but not
> >> through lst then pair, which is really confusing.
> > As I understand it, your first example works because it
> > structurally
> > decreases on a `lst` parameter. A `lst` can "contain itself" by
> > definition.
> > Your second example tries to decrease on a `pair`. As far as the
> > type
> > `pair` is concerned, the actual parameter is not structurally
> > smaller
> > than the formal parameter, it's just different.
> With that in mind, what about the following solution?
> Inductive lst :=
> | Nil | Cons : nat_lst_pair -> lst
> with nat_lst_pair :=
> | Both: nat -> lst -> nat_lst_pair.
> Fixpoint test2 p :=
> match p with
> | Both _ Nil => 0
> | Both _ (Cons l) => test2 l
> end.
This does work, but breaks the modularity of the pair type.
Thanks !
> www.mhelvens.net
- [Coq-Club] Fixpoint definition, Jacques-Henri Jourdan, 07/15/2013
- Re: [Coq-Club] Fixpoint definition, Pierre Casteran, 07/15/2013
- Re: [Coq-Club] Fixpoint definition, Michiel Helvensteijn, 07/15/2013
- Re: [Coq-Club] Fixpoint definition, Jacques-Henri Jourdan, 07/15/2013
- Re: [Coq-Club] Fixpoint definition, Jacques-Henri Jourdan, 07/16/2013
- Re: [Coq-Club] Fixpoint definition, Daniel Schepler, 07/16/2013
