coq-club - [Coq-Club] Odd failure of typeclass resolution
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Odd failure of typeclass resolution
  • Date: Tue, 16 Jul 2013 11:35:26 -0400
On code like [Definition foo := bar.], with [Set Printing All.], I get the error message
Toplevel input, characters 363-380:
Error:
Cannot infer this placeholder.
Could not find an instance for "IsTrunc (nat_to_trunc_index O)
                                  (Object (Index2Cat C'))" in environment:
fs : Funext
I : Type
Index2Cat : forall _ : I, PreCategory
H0 : forall i : I, IsTrunc (nat_to_trunc_index O) (Object (Index2Cat i))
C' : I
Setting [Typeclasses eauto := debug.] shows that coq jumps straight from the input to the error message, with no typeclass search in between.  If I replace [Definition foo := bar.] with [Definition foo : T. refine bar. Grab Existential Variables.  typeclasses eauto. Defined.], it goes through.  The relevant code is at theories/Groupoid/Functor.v in https://github.com/JasonGross/HoTT-categories/tree/typeclass-error.  Does anyone have any ideas what the problem might be?
Thanks,
Jason
