coq-club - [Coq-Club] renaming hypotheses with patterns?
  • From: Leonardo Rodriguez <leonardomatiasrodriguez AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] renaming hypotheses with patterns?
  • Date: Tue, 16 Jul 2013 13:59:10 -0300
Hi
I'm relatively new in Coq. I wonder how to write proofs which
are independent of the name generation algorithm of Coq.
For example, consider this tactic and the following lemma (a simplified version of my actual code)
Ltac rename_hyp Pattern H :=
  match goal with
      | [H' : Pattern |- _]
        => rename H' into H  ; clear H'
  end.
Inductive T : Prop :=
| a : T
| b : T.
Axiom P : Prop.
Axiom Q : T -> Prop.
Axiom R : T -> Prop.
Lemma whatever : P -> Q a -> Q b -> R b -> True.
  intros.
  rename_hyp P new_name_for_P.
  rename_hyp (Q a) new_name_for_Q_a.
  (* Doesn't work : *)
  rename_hyp (R _) new_name_for_R.
I want to write (or use) a tactic which can take any pattern as an argument.
But I also want  to ask in general, how to write proof independent of the names
generated by Coq.
Thank you!
