coq-club - Re: [Coq-Club] Odd failure of typeclass resolution
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: Jason Gross <jasongross9 AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Odd failure of typeclass resolution
  • Date: Fri, 19 Jul 2013 12:42:03 +0200
Hi Jason,
this was a bug in the type class resolution code, which failed to recognize
[?4 (Object (Index2Cat C'))] where ?4 was defined as [IsTrunc…] as a type
class evar.
This is fixed in the HoTT/coq repository.
Best,
-- Matthieu
On 16 juil. 2013, at 17:35, Jason Gross
wrote:
> On code like [Definition foo := bar.], with [Set Printing All.], I get the
> error message
> Toplevel input, characters 363-380:
> Error:
> Cannot infer this placeholder.
> Could not find an instance for "IsTrunc (nat_to_trunc_index O)
> (Object (Index2Cat C'))" in environment:
> fs : Funext
> I : Type
> Index2Cat : forall _ : I, PreCategory
> H0 : forall i : I, IsTrunc (nat_to_trunc_index O) (Object (Index2Cat i))
> C' : I
> Setting [Typeclasses eauto := debug.] shows that coq jumps straight from
> the input to the error message, with no typeclass search in between. If I
> replace [Definition foo := bar.] with [Definition foo : T. refine bar. Grab
> Existential Variables. typeclasses eauto. Defined.], it goes through. The
> relevant code is at theories/Groupoid/Functor.v in
> https://github.com/JasonGross/HoTT-categories/tree/typeclass-error. Does
> anyone have any ideas what the problem might be?
> Thanks,
> Jason
