[Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?
- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?
- Date: Fri, 19 Jul 2013 19:23:09 +0200
Hi all!
I have a problem very similar to that of Jacques-Henri Jourdan, which
he asked about on the list four days ago:
https://sympa.inria.fr/sympa/arc/coq-club/2013-07/msg00108.html
I've tried to figure it out by myself, but it's slow going. I could
use some help.
Take this simplified example of my own situation:
Inductive Test1 := t1list : list Test2 -> Test1
with Test2 := t2item : Test1 -> Test2.
Now I want to define a simple property on it, such as:
Require Import Coq.Lists.List.
Fixpoint short_lists1 t : Prop :=
match t with t1list lst =>
length lst < 10 /\
Forall (fun t2 => short_lists2 t2) lst
end
with short_lists2 t : Prop :=
match t with t2item t1 => short_lists1 t1 end.
Coq won't accept it, because I'm attempting structural reduction
through both `Test1` and `list`. (Note that I kept my example mutually
recursive because if I leave it out, any solution I find may or may
not work for my actual problem.)
(1) Most of what I've tried has been based on Daniel Schepler answer
to Jacques-Henri. He supplied a custom recursion principle. This lead
me to believe that perhaps Coq uses `mylist_rect` (or `mylist_rec`) to
check structural reduction by the `short_lists1` function.
Jacques-Henri seemed satisfied with the answer (though he mentions a
drawback). I myself, however, still cannot get his `short_lists1`
function accepted by Coq. What am I missing?
(2) Assuming that a custom recursion scheme is the solution, how
would you define one for my example above? I tried doing it manually
(and will continue to try), but could it perhaps be done by using
`Scheme` and friends (Chapter 13 of the manual)? That feels like it
would be more elegant.
Any advice would be appreciated!
www.mhelvens.net
- [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?, Michiel Helvensteijn, 07/19/2013
- Re: [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?, Adam Chlipala, 07/19/2013
- Re: [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?, Michiel Helvensteijn, 07/19/2013
- Re: [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?, Daniel Schepler, 07/19/2013
- [Coq-Club] Re: Proving structural reduction of an inductive type which is defined in terms of another?, Michiel Helvensteijn, 07/19/2013
