Re: [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?
- To: Michiel Helvensteijn <mhelvens AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?
- Date: Fri, 19 Jul 2013 14:07:47 -0700
On Fri, Jul 19, 2013 at 1:50 PM, Michiel Helvensteijn
wrote:
> On Fri, Jul 19, 2013 at 9:46 PM, Daniel Schepler
> <dschepler AT gmail.com>
> wrote:
>>> If possible, I'd still like a response to my question (1).
>> This is something like what I'd expect a mutual induction principle to
>> look like:
> That looks like it took some effort. :-)
> I assure you it's not wasted, because I'll study it. But my primary
> question is more basic:
> How can those definitions be used to get Coq to accept the definitions
> of `short_lists1` and `short_lists2`?
First, here's a simplified version of the recursion principle where
the result types are constant:
Definition Test1_rect_nondep {P Q:Type}
(rec_fun1 : list Test2 -> list Q -> P)
(rec_fun2 : Test1 -> P -> Q) : Test1 -> P :=
fix F (t1 : Test1) : P :=
match t1 with
| t1list l => rec_fun1 l (map G l)
end with
G (t2 : Test2) : Q :=
match t2 with
| t2item t => rec_fun2 t (F t)
end for F.
Definition Test2_rect_nondep {P Q:Type}
(rec_fun2 : Test1 -> P -> Q) : Test2 -> Q :=
match t1 with
end with
match t2 with
end for G.
Then, to use these to define your short_lists{1,2}:
Definition short_lists1 : Test1 -> Prop :=
Test1_rect_nondep
(fun (l : list Test2) (child_shortness : list Prop) =>
length l < 10 /\
Forall (fun P:Prop => P) child_shortness)
(fun _ (P:Prop) => P).
Definition short_lists2 : Test2 -> Prop :=
Test2_rect_nondep
length l < 10 /\
Daniel Schepler
- [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?, Michiel Helvensteijn, 07/19/2013
- Re: [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?, Adam Chlipala, 07/19/2013
- Re: [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?, Michiel Helvensteijn, 07/19/2013
- Re: [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?, Daniel Schepler, 07/19/2013
- [Coq-Club] Re: Proving structural reduction of an inductive type which is defined in terms of another?, Michiel Helvensteijn, 07/19/2013
