coq-club - Re: [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?
  • To: Adam Chlipala <adamc AT csail.mit.edu>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Proving structural reduction of an inductive type which is defined in terms of another?
  • Date: Fri, 19 Jul 2013 19:42:31 +0200
On Fri, Jul 19, 2013 at 7:26 PM, Adam Chlipala
wrote:
> I think if you define a variant of [Forall] based on recursion instead of
> induction, this will just work, since the termination checking understands
> the former but not the latter.
Aha, indeed! The following seems to work:
Require Import Coq.Lists.List.
Definition ForallRec {B} (P:B->Prop) (l: list B) : Prop :=
fold_left (fun p b => p /\ (P b)) l True.
Fixpoint short_lists1 t : Prop :=
match t with t1list lst =>
length lst < 10 /\
ForallRec (fun t2 => short_lists2 t2) lst
end
with short_lists2 t : Prop :=
match t with t2item t1 => short_lists1 t1 end.
I think this will work for my real-life problem too, so that's good.
;-) Unfortunately, it doesn't improve my understanding of recursion
schemes.
If possible, I'd still like a response to my question (1).
Thanks!
www.mhelvens.net
