- To: Bahman Sistany <bsistany AT yahoo.ca>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] existentially quantified proposition
- Date: Sat, 10 Aug 2013 09:37:59 -0400
If you're willing to tolerate a logically equivalent quantifier
rearrangement, there's: Fixpoint separated (t t' len : nat) : Prop := match len with | O => t < t' | S len' => exists n, t < n /\ separated n t' len' end. On 08/10/2013 08:39 AM, Rui Baptista wrote: How about this?
Require Import Coq.Lists.List. Fixpoint gen'' (l : list nat) : Prop := match l with | nil => True | cons x l' => match l' with | nil => True | cons x' _ => x < x' /\ gen'' l' end end. Fixpoint gen' (t' len : nat) (l : list nat) : Prop := match len with | 0 => gen'' (rev (cons t' l)) | S len' => exists x, gen' t' len' (cons x l) end. Definition gen (t t' len : nat) : Prop := match len with | 0 => True | S len' => gen' t' len' (cons t nil) end. Eval simpl in forall t t', gen t t' 0. Eval simpl in forall t t', gen t t' 1. Eval simpl in forall t t', gen t t' 2. Eval simpl in forall t t', gen t t' 3. Eval simpl in forall t t', gen t t' 4. On Sat, Aug 10, 2013 at 7:15 AM, Bahman
wrote:
Hi,
Fixpoint gen (t t' : nat)(len:nat) : Prop := ??? (* When len=2, I need: *) exists x2, (t < x2 < t') (* When len=3, I need: *) exists x2, x3 (t < x2 < x3 < t') ... I have been working on various ways of extending 'ex' but nothing works so far. Any thoughts on the general problem would be appreciated. --Bahman |
- [Coq-Club] existentially quantified proposition, Bahman Sistany, 08/10/2013
- Re: [Coq-Club] existentially quantified proposition, Rui Baptista, 08/10/2013
- Re: [Coq-Club] existentially quantified proposition, Adam Chlipala, 08/10/2013
- Re: [Coq-Club] existentially quantified proposition, Bahman Sistany, 08/10/2013
