coq-club - Re: [Coq-Club] existentially quantified proposition
  • To: Adam Chlipala <adamc AT csail.mit.edu>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] existentially quantified proposition
  • Date: Sat, 10 Aug 2013 10:16:09 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.ca; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:Cc:In-Reply-To:MIME-Version:Content-Type; b=nHLCNbBginfVFYthJNfXcs9evD6/8lUljl2oguYhhv7+1vaeeVDAbDPDk+dVBUbf8b8mnBG/DL7Wb7OU4KDb/KFRjKdvSbrEbtewpjv9Ole2GbOR4X6VCK9CuQU9XQiVrE2I/kwllOaB1t+786ug4iOeTs9LOddMZ+FU+c8BwHY=;
Thanks to all. The equivalent formula works fine for me.
I notice coq does some renaming of variables: n0, n1, ... which intuitively makes sense in this case. However, what is the general rule by which such renaming happens?
--Bahman
To: Bahman Sistany <bsistany AT yahoo.ca>
Sent: Saturday, August 10, 2013 9:37:59 AM
If you're willing to tolerate a logically equivalent quantifier rearrangement, there's:
Fixpoint separated (t t' len : nat) : Prop :=
  match len with
    | O => t < t'
    | S len' => exists n, t < n /\ separated n t' len'
  end.
On 08/10/2013 08:39 AM, Rui Baptista wrote:
How about this?
Require Import Coq.Lists.List.
Fixpoint gen'' (l : list nat) : Prop :=
  match l with
  | nil => True
  | cons x l' =>
    match l' with
    | nil => True
    | cons x' _ => x < x' /\ gen'' l'
    end
  end.
Fixpoint gen' (t' len : nat) (l : list nat) : Prop :=
  match len with
  | 0 => gen'' (rev (cons t' l))
  | S len' => exists x, gen' t' len' (cons x l)
  end.
Definition gen (t t' len : nat) : Prop :=
  match len with
  | 0 => True
  | S len' => gen' t' len' (cons t nil)
  end.
Eval simpl in forall t t', gen t t' 0.
Eval simpl in forall t t', gen t t' 1.
Eval simpl in forall t t', gen t t' 2.
Eval simpl in forall t t', gen t t' 3.
Eval simpl in forall t t', gen t t' 4.
On Sat, Aug 10, 2013 at 7:15 AM, Bahman Sistany <bsistany AT yahoo.ca> wrote:
Hi,
I am trying to come up with an existentially quantified proposition where I generate the witnesses (xi's here) and the property programmatically/dynamically.
Fixpoint gen (t t' : nat)(len:nat) : Prop := ???
(* When len=2, I need: *)
exists x2, (t < x2 < t')
(* When len=3, I need: *)
exists x2, x3 (t < x2 < x3 < t')
I have been working on various ways of extending 'ex' but nothing works so far. Any thoughts on the general problem would be appreciated.
--Bahman
