- To: Bahman Sistany <bsistany AT yahoo.ca>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] existentially quantified proposition
- Date: Sat, 10 Aug 2013 13:39:04 +0100
How about this?
Require Import Coq.Lists.List.
Fixpoint gen'' (l : list nat) : Prop :=
match l with
| nil => True
| cons x l' =>
match l' with
| nil => True
| cons x' _ => x < x' /\ gen'' l'
end
end.
Fixpoint gen' (t' len : nat) (l : list nat) : Prop :=
match len with
| 0 => gen'' (rev (cons t' l))
| S len' => exists x, gen' t' len' (cons x l)
end.
Definition gen (t t' len : nat) : Prop :=
match len with
| 0 => True
| S len' => gen' t' len' (cons t nil)
end.
Eval simpl in forall t t', gen t t' 0.
Eval simpl in forall t t', gen t t' 1.
Eval simpl in forall t t', gen t t' 2.
Eval simpl in forall t t', gen t t' 3.
Eval simpl in forall t t', gen t t' 4.
match l with
| nil => True
| cons x l' =>
match l' with
| nil => True
end
end.
match len with
end.
match len with
| 0 => True
end.
On Sat, Aug 10, 2013 at 7:15 AM, Bahman Sistany <bsistany AT yahoo.ca> wrote:
Hi,I am trying to come up with an existentially quantified proposition where I generate the witnesses (xi's here) and the property programmatically/dynamically.Fixpoint gen (t t' : nat)(len:nat) : Prop := ???(* When len=2, I need: *)exists x2, (t < x2 < t')(* When len=3, I need: *)exists x2, x3 (t < x2 < x3 < t')...I have been working on various ways of extending 'ex' but nothing works so far. Any thoughts on the general problem would be appreciated.--Bahman
- [Coq-Club] existentially quantified proposition, Bahman Sistany, 08/10/2013
- Re: [Coq-Club] existentially quantified proposition, Duckki Oe, 08/10/2013
- Re: [Coq-Club] existentially quantified proposition, Rui Baptista, 08/10/2013
- Re: [Coq-Club] existentially quantified proposition, Adam Chlipala, 08/10/2013
- Re: [Coq-Club] existentially quantified proposition, Bahman Sistany, 08/10/2013
