coq-club - Re: [Coq-Club] tactic databases
  • To: t x <txrev319 AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] tactic databases
  • Date: Tue, 20 Aug 2013 00:16:25 -0400
Tactic notations can be rebound while making use of the old value.  For example,
Ltac a := pose 1 as a.
Tactic Notation "nuke" := a.
Ltac b := pose 2 as b.
Tactic Notation "nuke" := (nuke; b).
(As an aside, I have not figured out how to print the script of a tactic notation.  Can someone tell me how to do this?)
There is not currently a notion of a database of tactics, other than those of auto or rewrite, so you'd have to write an OCaml plugin if you wanted to use that path.  However, I vaguely recall this being mentioned on coq-club in the past, and that there might be such custom databases in future versions of Coq.  Someone more knowledgeable than I (or willing to do more archive-digging) might be able to say more.
-JAson
On Monday, August 19, 2013, t x wrote:
Hi,
  I have an tactic that looks something like:
===== nuke.v
Ltac nuke = repeat ( tac1 || tac2 || tac3 || tac4 ).
===== foo.v
Require Import nuke.
Some definitions.
Ltac foo_solver = ...
I would now like to rebind:
Ltac nuke = repeat (tac1 || tac2 || tac3 || tac4 || foo_solver).
===== bar.v
Require Import nuke foo.
Some definitions related to bar.
Ltac bar_solver = ...
Ltac nuke = repeat (tac1 || tac2 || tac3 || tac4 || foo_solver || bar_solver).
#### What I've tried so far:
Hint Extern <-- this does not appear to work because "auto" wants tactics that solves the subgoals. Whereas in my case, the job of each tacX is to simplify/split the goal into simpler subgoals.
#### What I'd like:
I would like something similar to a Hint Rewrite Database.
Something like:
===== nuke.v ...
Hint Use tac1 : nukedb
Hint Use tac2 : nukedb
Ltac nuke = repeat with nukedb.
===== foo.v
Hint Use foo_solver : nukedb.
(at this point, "nuke" tactic also uses foo_solver
===== bar.b
Hint Use bar_solver :nukedb.
(at this point, "nuke" tactic also uses bar_solver)
Is there a way to setup this up in Ltac, or does this go into the realms of Ocaml plugins?
Thanks!
