- To: t x <txrev319 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] tactic databases
- Date: Tue, 20 Aug 2013 13:49:48 -0400
I'm glad it works. Is the meaning of ::= documented somewhere in the reference manual? What does it do?
-Jason
On Aug 20, 2013 2:38 AM, "t x" <txrev319 AT gmail.com> wrote:
Jason: your idea worked.Using the following, I can fake a "add only tactic database"==== nuke.v Tactic Notation "nuke_tacs" := initial_set_of_tacs. Ltac nuke_update := nuke_tacs. Ltac nuke := .... do some stuff ...; repeat (nuke_update || ... tacs ...); .... do some more stuff ... . ==== to register a new tac Tactic Notation "nuke_tacs" := new_tac || nuke_tacs. (* Tactic Notation does not support recursion. Thus, the second nuke_tacs gets the old value. *) (* Now, we need to force the "nuke" tactic to use the latest nuke_tacs *) Ltac nuke_update ::= nuke_tacs. (* the ::= ensure taht nuke_update has the latest nuke_tacs; and forces
nuke to use the latest nuke_update *).On Tue, Aug 20, 2013 at 6:29 AM, t x <txrev319 AT gmail.com> wrote:
I'm going the OCaml route. If anyone knows of any tutorial besides http://gallium.inria.fr/blog/your-first-coq-plugin/ I would appreciate it. (It seems like the main difficulties is just understanding boiler plate.)re re-binding:I was
* playing with "Ltac ... ::=" (note the double ::), for examp;e
Ltac nuke_split := new_tac || nuke_split
* getting stack overflows
* attributing said stack overflows to the 2nd nuke_split referring to the new rather than the old value (since Ltacs can recursively call itself)* however, perhaps Tactic Notation's inability to recurse might be useful in this case.re plugins:
* I will re-investigate on this and report back.
On Tue, Aug 20, 2013 at 4:16 AM, Jason Gross <jasongross9 AT gmail.com> wrote:
Tactic notations can be rebound while making use of the old value. For example,Ltac a := pose 1 as a.Tactic Notation "nuke" := a.Ltac b := pose 2 as b.Tactic Notation "nuke" := (nuke; b).(As an aside, I have not figured out how to print the script of a tactic notation. Can someone tell me how to do this?)There is not currently a notion of a database of tactics, other than those of auto or rewrite, so you'd have to write an OCaml plugin if you wanted to use that path. However, I vaguely recall this being mentioned on coq-club in the past, and that there might be such custom databases in future versions of Coq. Someone more knowledgeable than I (or willing to do more archive-digging) might be able to say more.-JAson
On Monday, August 19, 2013, t x wrote:Some definitions related to bar.Require Import nuke foo.===== bar.vI would now like to rebind:Ltac foo_solver = ...Hi,I have an tactic that looks something like:
===== nuke.v
Ltac nuke = repeat ( tac1 || tac2 || tac3 || tac4 ).
===== foo.v
Require Import nuke.
Some definitions.
Ltac nuke = repeat (tac1 || tac2 || tac3 || tac4 || foo_solver).
Ltac bar_solver = ...I would now like to rebind:
Ltac nuke = repeat (tac1 || tac2 || tac3 || tac4 || foo_solver || bar_solver).
#### What I've tried so far:
Hint Extern <-- this does not appear to work because "auto" wants tactics that solves the subgoals. Whereas in my case, the job of each tacX is to simplify/split the goal into simpler subgoals.
#### What I'd like:I would like something similar to a Hint Rewrite Database.Something like:===== nuke.v ...Hint Use tac1 : nukedb
Hint Use tac2 : nukedbLtac nuke = repeat with nukedb.===== foo.vHint Use foo_solver : nukedb.(at this point, "nuke" tactic also uses foo_solver
===== bar.b
Hint Use bar_solver :nukedb.(at this point, "nuke" tactic also uses bar_solver)Is there a way to setup this up in Ltac, or does this go into the realms of Ocaml plugins?
Thanks!
- [Coq-Club] tactic databases, t x, 08/20/2013
- Re: [Coq-Club] tactic databases, Jason Gross, 08/20/2013
- Re: [Coq-Club] tactic databases, t x, 08/20/2013
- Re: [Coq-Club] tactic databases, Valentin Robert, 08/20/2013
