coq-club - Re: [Coq-Club] tactic databases
  • To: Jason Gross <jasongross9 AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] tactic databases
  • Date: Tue, 20 Aug 2013 06:29:08 +0000
re re-binding:
  I was
  * playing with "Ltac ... ::=" (note the double ::), for examp;e
Ltac nuke_split := new_tac || nuke_split
  * getting stack overflows
  * attributing said stack overflows to the 2nd nuke_split referring to the new rather than the old value (since Ltacs can recursively call itself)
  * however, perhaps Tactic Notation's inability to recurse might be useful in this case.
  * I will re-investigate on this and report back.
re plugins:
  I'm going the OCaml route. If anyone knows of any tutorial besides http://gallium.inria.fr/blog/your-first-coq-plugin/ I would appreciate it. (It seems like the main difficulties is just understanding boiler plate.)
On Tue, Aug 20, 2013 at 4:16 AM, Jason Gross <jasongross9 AT gmail.com> wrote:
Tactic notations can be rebound while making use of the old value.  For example,
Ltac a := pose 1 as a.
Tactic Notation "nuke" := a.
Ltac b := pose 2 as b.
Tactic Notation "nuke" := (nuke; b).
(As an aside, I have not figured out how to print the script of a tactic notation.  Can someone tell me how to do this?)
There is not currently a notion of a database of tactics, other than those of auto or rewrite, so you'd have to write an OCaml plugin if you wanted to use that path.  However, I vaguely recall this being mentioned on coq-club in the past, and that there might be such custom databases in future versions of Coq.  Someone more knowledgeable than I (or willing to do more archive-digging) might be able to say more.
-JAson
On Monday, August 19, 2013, t x wrote:
Hi,
  I have an tactic that looks something like:
===== nuke.v
Ltac nuke = repeat ( tac1 || tac2 || tac3 || tac4 ).
===== foo.v
Require Import nuke.
Some definitions.
Ltac foo_solver = ...
I would now like to rebind:
Ltac nuke = repeat (tac1 || tac2 || tac3 || tac4 || foo_solver).
===== bar.v
Require Import nuke foo.
Some definitions related to bar.
Ltac bar_solver = ...
Ltac nuke = repeat (tac1 || tac2 || tac3 || tac4 || foo_solver || bar_solver).
#### What I've tried so far:
Hint Extern <-- this does not appear to work because "auto" wants tactics that solves the subgoals. Whereas in my case, the job of each tacX is to simplify/split the goal into simpler subgoals.
#### What I'd like:
I would like something similar to a Hint Rewrite Database.
Something like:
===== nuke.v ...
Hint Use tac1 : nukedb
Hint Use tac2 : nukedb
Ltac nuke = repeat with nukedb.
===== foo.v
Hint Use foo_solver : nukedb.
(at this point, "nuke" tactic also uses foo_solver
===== bar.b
Hint Use bar_solver :nukedb.
(at this point, "nuke" tactic also uses bar_solver)
Is there a way to setup this up in Ltac, or does this go into the realms of Ocaml plugins?
Thanks!
