coq-club - Re: [Coq-Club] Universe polymorphism in the HoTT branch of Coq
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: vincent rahli <vincent.rahli AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Universe polymorphism in the HoTT branch of Coq
  • Date: Fri, 6 Sep 2013 11:01:38 +0200
On 6 sept. 2013, at 01:07, vincent rahli
wrote:
> Hi,
> We're trying to use the HoTT branch of Coq (downloaded today) in order to
> get
> universe polymorphism.
> Unfortunately we keep on running into this error [Error: Universe
> inconsistency],
> which is the very error we were trying to avoid by using the HoTT branch of
> Coq.
> One of our problems is that [try] does not catch this error (see the code
> below).
> - Why doesn't [try] catch that error?
> - Why do we get a universe inconsistency error here and not
> [Error: Unable to unify.] (without the [try])?
Hi,
Indeed that version of unification didn't turn inconsistencies into
unification
failures. The current development version [1] fixes this, I hope to push it
to the
HoTT/coq repository soon. The proof goes through though if you avoid this
step:
Proof.
induction sub; simpl; intros.
destruct H.
simpl in IHsub.
split; try right; (apply (IHsub vars);
destruct a, sub; [apply X| destruct p; apply X]).
Qed.
Also, as a workaround, putting NTerm in [Set] where it naturally falls gets
rid
of the inconsistency.
[1]
git AT github.com:mattam82/coq.git
branch univpolyproj
Best,
-- Matthieu
> Thanks.
> Vincent & Abhishek.
> Require Export Coq.Lists.List.
> Polymorphic Fixpoint LIn (A : Type) (a:A) (l:list A) : Type :=
> match l with
> | nil => False
> | b :: m => (b = a) + LIn A a m
> end.
> Polymorphic Inductive NTerm : Type :=
> | cterm : NTerm
> | oterm : list NTerm -> NTerm.
> Polymorphic Fixpoint dummy {A B} (x : list (A * B)) : list (A * B) :=
> match x with
> | nil => nil
> | (_, _) :: _ => nil
> end.
> Lemma foo :
> forall v t sub vars,
> LIn (nat * NTerm) (v, t) (dummy sub)
> LIn (nat * NTerm) (v, t) sub
> notT (LIn nat v vars)
> Proof.
> destruct H.
> try (apply IHsub in X).
