- To: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- Cc: vincent rahli <vincent.rahli AT gmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Universe polymorphism in the HoTT branch of Coq
- Date: Sat, 7 Sep 2013 04:48:48 -0400
How can I compile git AT github.com:mattam82/coq.git? When I run `./configure -no-native-compiler -prefix "$HOME/.local64/coq/coq-univpolyproj/"` and then `make -j16 -k` and then I run `make -j16 -k` again, I get
$ make -j16 -k
make --warn-undefined-variable --no-builtin-rules -f Makefile.build "world"
make[1]: Entering directory `/afs/csail.mit.edu/u/j/jgross/coq-univpolyproj'
CHECK revision
OCAMLOPT kernel/term_typing.ml
OCAMLC kernel/term_typing.ml
./doc/stdlib/make-library-index doc/stdlib/index-list.html doc/stdlib/hidden-files
File "kernel/term_typing.ml", line 31, characters 32-33:
Error: This _expression_ has type Environ.unsafe_judgment
but an _expression_ was expected of type Term.constr = Constr.t
make[1]: *** [kernel/term_typing.cmx] Error 2
Building file index-list.prehtml ...theories/Arith
make[1]: *** [kernel/term_typing.cmo] Error 2
theories/Bool
theories/Classes
Error: none of doc/stdlib/index-list.html and doc/stdlib/hidden-files mention theories/Classes/CEquivalence.v
make[1]: *** [doc/stdlib/index-list.html] Error 1
make[1]: Target `world' not remade because of errors.
make[1]: Leaving directory `/afs/csail.mit.edu/u/j/jgross/coq-univpolyproj'
make: *** [world] Error 2
make: Target `NOARG' not remade because of errors.
Thanks,
Jason
On Friday, September 6, 2013, Matthieu Sozeau wrote:
On 6 sept. 2013, at 01:07, vincent rahli <vincent.rahli AT gmail.com> wrote:
> Hi,
> We're trying to use the HoTT branch of Coq (downloaded today) in order to get
> universe polymorphism.
> Unfortunately we keep on running into this error [Error: Universe inconsistency],
> which is the very error we were trying to avoid by using the HoTT branch of Coq.
> One of our problems is that [try] does not catch this error (see the code below).
> - Why doesn't [try] catch that error?
> - Why do we get a universe inconsistency error here and not
> [Error: Unable to unify.] (without the [try])?
Hi,
Indeed that version of unification didn't turn inconsistencies into unification
failures. The current development version [1] fixes this, I hope to push it to the
HoTT/coq repository soon. The proof goes through though if you avoid this step:
Proof.
induction sub; simpl; intros.
destruct H.
simpl in IHsub.
split; try right; (apply (IHsub vars);
destruct a, sub; [apply X| destruct p; apply X]).
Qed.
Also, as a workaround, putting NTerm in [Set] where it naturally falls gets rid
of the inconsistency.
[1] git AT github.com:mattam82/coq.git branch univpolyproj
Best,
-- Matthieu
> Thanks.
> Vincent & Abhishek.
> Require Export Coq.Lists.List.
> Polymorphic Fixpoint LIn (A : Type) (a:A) (l:list A) : Type :=
> match l with
> | nil => False
> | b :: m => (b = a) + LIn A a m
> end.
> Polymorphic Inductive NTerm : Type :=
> | cterm : NTerm
> | oterm : list NTerm -> NTerm.
> Polymorphic Fixpoint dummy {A B} (x : list (A * B)) : list (A * B) :=
> match x with
> | nil => nil
> | (_, _) :: _ => nil
> end.
> Lemma foo :
> forall v t sub vars,
> LIn (nat * NTerm) (v, t) (dummy sub)
> LIn (nat * NTerm) (v, t) sub
> notT (LIn nat v vars)
> Proof.
> destruct H.
> try (apply IHsub in X).
- [Coq-Club] Universe polymorphism in the HoTT branch of Coq, vincent rahli, 09/06/2013
- Re: [Coq-Club] Universe polymorphism in the HoTT branch of Coq, Jason Gross, 09/06/2013
- Re: [Coq-Club] Universe polymorphism in the HoTT branch of Coq, Matthieu Sozeau, 09/06/2013
- Re: [Coq-Club] Universe polymorphism in the HoTT branch of Coq, Jason Gross, 09/07/2013
- Re: [Coq-Club] Universe polymorphism in the HoTT branch of Coq, vincent rahli, 09/07/2013
