coq-club - Re: [Coq-Club] Universe polymorphism in the HoTT branch of Coq
  • To: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Universe polymorphism in the HoTT branch of Coq
  • Date: Sat, 7 Sep 2013 12:36:00 -0400
Thanks a lot for your quick replies.
I forgot to mention that the version we're using is that one:
   https://github.com/HoTT/coq.
I should also have mentioned that that [try] in the proof script is really something
that one of our tactic tries.
One issue we're having now is that with these definitions tagged with [Polymorphic]
what was taking a few minutes to compile now takes several hours.
Is there a workaround that problem?
Thanks.
Vincent.
On Fri, Sep 6, 2013 at 5:01 AM, Matthieu Sozeau <matthieu.sozeau AT gmail.com> wrote:
On 6 sept. 2013, at 01:07, vincent rahli <vincent.rahli AT gmail.com> wrote:
> Hi,
> We're trying to use the HoTT branch of Coq (downloaded today) in order to get
> universe polymorphism.
> Unfortunately we keep on running into this error [Error: Universe inconsistency],
> which is the very error we were trying to avoid by using the HoTT branch of Coq.
> One of our problems is that [try] does not catch this error (see the code below).
>   - Why doesn't [try] catch that error?
>   - Why do we get a universe inconsistency error here and not
>     [Error: Unable to unify.] (without the [try])?
Hi,
  Indeed that version of unification didn't turn inconsistencies into unification
failures. The current development version [1] fixes this, I hope to push it to the
HoTT/coq repository soon. The proof goes through though if you avoid this step:
Proof.
induction sub; simpl; intros.
destruct H.
simpl in IHsub.
split; try right; (apply (IHsub vars);
destruct a, sub; [apply X| destruct p; apply X]).
Qed.
  Also, as a workaround, putting NTerm in [Set] where it naturally falls gets rid
of the inconsistency.
[1] git AT github.com:mattam82/coq.git branch univpolyproj
Best,
-- Matthieu
> Thanks.
> Vincent & Abhishek.
> Require Export Coq.Lists.List.
> Polymorphic Fixpoint LIn (A : Type) (a:A) (l:list A) : Type :=
>   match l with
>     | nil => False
>     | b :: m => (b = a) + LIn A a m
>   end.
> Polymorphic Inductive NTerm : Type :=
> | cterm : NTerm
> | oterm : list NTerm -> NTerm.
> Polymorphic Fixpoint dummy {A B} (x : list (A * B)) : list (A * B) :=
>   match x with
>     | nil => nil
>     | (_, _) :: _ => nil
>   end.
> Lemma foo :
>   forall v t sub vars,
>     LIn (nat * NTerm) (v, t) (dummy sub)
>       LIn (nat * NTerm) (v, t) sub
>       notT (LIn nat v vars)
> Proof.
>   destruct H.
>   try (apply IHsub in X).
