- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to talk about a restricted set of an inductive?
- Date: Thu, 3 Oct 2013 13:40:23 +0200
I know that in my example the property is not true in general.
I would like to know if there is a way to restrict the statement onNList_ which have been created by NList (for which the statement is true).
On Thu, Oct 3, 2013 at 1:32 PM, Rui Baptista <rpgcbaptista AT gmail.com> wrote:
But I'm able to disprove your assertion.Goal ~ forall A l n, @NList_ A n l -> length l = n.Proof.intro H1.pose proof (H1 nat) as H2.pose proof (H2 (cons 0 nil)) as H3.pose proof (H3 0) as H4.pose proof @Base as H5.pose proof (H5 nat) as H6.pose proof (H6 (cons 0 nil)) as H7.pose proof (H4 H7) as H8.simpl in H8.discriminate H8.Defined.On Thu, Oct 3, 2013 at 12:17 PM, Fabien Renaud <Fabien.Renaud AT inria.fr> wrote:
This is an illustration of my problem and in my case I cannot change it.On Thu, Oct 3, 2013 at 12:44 PM, Rui Baptista <rpgcbaptista AT gmail.com> wrote:
If you're willing to change "Base l: NList_ 0 l" to "Base: NList_ 0 nil", you can do it like so:Goal forall A l n, @NList_ A n l -> length l = n.Proof. induction 1. reflexivity. subst. reflexivity. Defined.On Thu, Oct 3, 2013 at 11:01 AM, Fabien Renaud <Fabien.Renaud AT inria.fr> wrote:
forall l n, NList_ n l -> length l = n?Is there a way to state properties about NList_ created by NList likeNow I want to start building NList_ such that the first argument is always the length of the list:Hello,The subject of my question is not very clear but my problem yes:
For the illustration, suppose I have this (weird) inductive:
Inductive NList_ {A : Type} : nat -> list A -> Type :=
| Base l: NList_ 0 l
| Cons n l a: NList_ n l -> NList_ (S n) (a::l).
Definition NList {A : Type} (l : list A) := NList_ (length l) l.Thanks,Fabien
- [Coq-Club] How to talk about a restricted set of an inductive?, Fabien Renaud, 10/03/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Rui Baptista, 10/03/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Fabien Renaud, 10/03/2013
- Message not available
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Robbert Krebbers, 10/03/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Cedric Auger, 10/03/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Jonas Oberhauser, 10/04/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Fabien Renaud, 10/04/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Jean-Francois Monin, 10/04/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Cedric Auger, 10/04/2013
