coq-club - Re: [Coq-Club] How to talk about a restricted set of an inductive?
  • To: Fabien Renaud <Fabien.Renaud AT inria.fr>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] How to talk about a restricted set of an inductive?
  • Date: Thu, 3 Oct 2013 14:35:29 +0200
You can use subtypes:
Inductive subNList {A : Type} (n : nat) (l : list A) -> Type :=
 Sub : List.length l = n -> NList_ n l -> subNList n l.
The standard library uses also {x | P x} (the 'sig' type).
Note that your type has no real content, as once A, n and l are fixed, you do not have much choice to build a NList_ n l.
In fact either NList_ n l is empty, either it is a singleton.
I did not do it, but I am pretty sure you can prove:
∀ A n (l : list A) (x y : NList_ n l), x = y.
starting with something like:
intros A n l x; induction x.
The inversion on y seems a little tricky, but still doable.
2013/10/3 Fabien Renaud <Fabien.Renaud AT inria.fr>
I know that in my example the property is not true in general.
I would like to know if there is a way to restrict the statement on
NList_ which have been created by NList (for which the statement is true).
On Thu, Oct 3, 2013 at 1:32 PM, Rui Baptista <rpgcbaptista AT gmail.com> wrote:
But I'm able to disprove your assertion.
Goal ~ forall A l n, @NList_ A n l -> length l = n.
Proof.
intro H1.
pose proof (H1 nat) as H2.
pose proof (H2 (cons 0 nil)) as H3.
pose proof (H3 0) as H4.
pose proof @Base as H5.
pose proof (H5 nat) as H6.
pose proof (H6 (cons 0 nil)) as H7.
pose proof (H4 H7) as H8.
simpl in H8.
discriminate H8.
Defined.
On Thu, Oct 3, 2013 at 12:17 PM, Fabien Renaud <Fabien.Renaud AT inria.fr> wrote:
This is an illustration of my problem and in my case I cannot change it.
On Thu, Oct 3, 2013 at 12:44 PM, Rui Baptista <rpgcbaptista AT gmail.com> wrote:
If you're willing to change "Base l: NList_ 0 l" to "Base: NList_ 0 nil", you can do it like so:
Goal forall A l n, @NList_ A n l -> length l = n.
Proof. induction 1. reflexivity. subst. reflexivity. Defined.
On Thu, Oct 3, 2013 at 11:01 AM, Fabien Renaud <Fabien.Renaud AT inria.fr> wrote:
Hello,
The subject of my question is not very clear but my problem yes:
For the illustration, suppose I have this (weird) inductive:
Inductive NList_ {A : Type} : nat -> list A -> Type :=
| Base l: NList_ 0 l
| Cons n l a: NList_ n l -> NList_ (S n) (a::l).
Now I want to start building NList_ such that the first argument is always the length of the list:
Definition NList {A : Type} (l : list A) := NList_ (length l) l.
Is there a way to state properties about NList_ created by NList like
forall l n, NList_ n l -> length l = n?
Thanks,
Fabien
.../Sedrikov\...
