- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: Fabien Renaud <Fabien.Renaud AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to talk about a restricted set of an inductive?
- Date: Fri, 4 Oct 2013 10:54:07 +0200
Your conjecture is wrong:
Lemma wrong: SubPlist (0 :: nil).
Proof.
apply Sub. apply Skip.
- apply Base.
- repeat constructor.
Qed.
Jean-Francois
On Fri, Oct 04, 2013 at 10:23:29AM +0200, Fabien Renaud wrote:
> Hi,
> This is the kind of things I want but I actually simplified too much my
> problem.
> Take this inductive:
> Inductive Plist : list nat -> list nat -> Type :=
> | Base l : Plist l nil
> | Move l x l': Plist (x::l) l' -> x > 10 -> Plist l (x::l')
> | Skip l x l': Plist l l' -> x <= 10 -> Plist l (x::l')
> (In my real problem, I cannot as well give a better base case since free
> duplication can happen).
> Now I would to restrict to Plist which are started with an empty left list:
> Inductive SubPlist : list nat -> Type :=
> | Sub l : Plist nil l -> SubPlist l.
> I would like to be able to prove that for all Plist coming from SubPlist,
> all the elements are strictly greater than 10.
> But there is now (wrt to the previous example), no way to
> immediately conclude since this is a consequence.
> So once again I'm wondering how should I do?
> On Fri, Oct 4, 2013 at 4:01 AM, Jonas Oberhauser
> <s9joober AT gmail.com>
> wrote:
> > Am 03.10.2013 14:35, schrieb Cedric Auger:
> > A n (l : list A) (x y : NList_ n l), x = y.
> > Jup. There might be a simpler proof, but here is one:
> > Lemma NList_Unique {A} (l : list A) n (y : NList_ n l): match n return
> > NList_ n l -> Prop with
> > | 0 => fun y => Base l = y
> > | S n' =>
> > match l with
> > | nil => fun y => False
> > | cons a l' => fun y => exists x : NList_ n' l', Cons n' l' a x = y
> > end
> > end y.
> > induction y ; auto.
> > exists y ; auto.
> > Qed.
> > Goal forall A n (l : list A) (x y : NList_ n l), x = y.
> > induction x.
> > apply (NList_Unique l).
> > intros y.
> > destruct (NList_Unique (a :: l) (S n) y) as [x' P].
> > now rewrite IHx with x'.
> > Qed.
Jean-Francois Monin
VERIMAG
Universite de Grenoble 1
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, (continued)
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Fabien Renaud, 10/03/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Rui Baptista, 10/03/2013
- Message not available
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Robbert Krebbers, 10/03/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Cedric Auger, 10/03/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Jonas Oberhauser, 10/04/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Fabien Renaud, 10/04/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Jean-Francois Monin, 10/04/2013
- Re: [Coq-Club] How to talk about a restricted set of an inductive?, Cedric Auger, 10/04/2013
