coq-club - Re: [Coq-Club] Induction over ascii
  • To: Marcus Ramos <mvmramos AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Induction over ascii
  • Date: Thu, 24 Oct 2013 10:10:48 -0700
You're right. I screwed up. I incorrectly linked lower with -, when it was clearly defined with +. I think simpl, omega should solve this lemma.
Marcus Ramos <mvmramos AT gmail.com> wrote:
Since I add first and subtract later, I don´t think this situation will happen. Anyway, it is just an example, and could be improved to ensure that arguments are in the range "A"-"Z" for lower and "a"-"z" for upper. But the point is on how to prove by induction on ascii.
2013/10/24 t x <txrev319 AT gmail.com>
I don't think the lemma is true. In Coq, (0 - 32) + 32 = 0 + 32 = 32.
On Thu, Oct 24, 2013 at 9:46 AM, Marcus Ramos <mvmramos AT gmail.com> wrote:
Hi,
This is probably a very basic question, but since I have no teacher to ask about, I guess whether any of you would give me a hint on how to prove the following theorem (a reduced version of the problem I am working with):
Require Import Ascii.
Definition upper (c: ascii): ascii := ascii_of_nat ((nat_of_ascii c)-32).
Definition lower (c: ascii): ascii := ascii_of_nat ((nat_of_ascii c)+32).
Theorem t:
   forall c: ascii,
   upper (lower c) = c.
It has to do with proving by induction over ascii, but I have no idea on how to do it. Once again, sorry for bothering with basic questions...
Thanks in advance,
Marcus.
