- To: Marcus Ramos <marcus.ramos AT univasf.edu.br>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Induction over ascii
- Date: Thu, 24 Oct 2013 22:53:56 +0200
Le Thu, 24 Oct 2013 16:43:11 -0200,
Marcus Ramos
a écrit :
> Thanks for all the replies. I fixed the example, so now I think it
> can be proved in all cases:
> Require Import Ascii.
> Require Import NPeano.
> Definition change_case (c: ascii): ascii :=
> let c': nat := nat_of_ascii c in
> if andb (65 <=? c') (c' <=? 90) then ascii_of_nat (c'+32)
> else if andb (97 <=? c') (c' <=? 122) then ascii_of_nat (c'-32)
> else c.
> Lemma change:
> forall c: ascii,
> change_case (change_case c) = c.
> Proof.
> intros [[][][][][][][][]].
> reflexivity.
> reflexivity.
> My question however remains: do I have to write "reflexivity" 256
> times (that is, consider 256 different goals) in order to prove this
> lemma? Or is there an easier way to do this?
> Best Regards,
> Marcus.
intros [[][][][][][][][]]; reflexivity.
This should do it. Simply replace '.' by ';'. For more information,
read the reference manual, or hope someone will explain it.
But again, flipping the right bit is a lot simpler than converting
to nat (and way more efficient).
- [Coq-Club] Induction over ascii, Marcus Ramos, 10/24/2013
- Re: [Coq-Club] Induction over ascii, t x, 10/24/2013
- Re: [Coq-Club] Induction over ascii, Marcus Ramos, 10/24/2013
- Re: [Coq-Club] Induction over ascii, AUGER Cédric, 10/24/2013
- <Possible follow-up(s)>
- Re: [Coq-Club] Induction over ascii, txrev319, 10/24/2013
- Re: [Coq-Club] Induction over ascii, Chris Dams, 10/24/2013
