- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Building coq on Windows under cygwin
- Date: Tue, 5 Nov 2013 21:47:11 -0500
How do I build coq on windows? When I run ./configure and make, I get
$ ./configure -local
You have GNU Make 4.0. Good!
You have Objective-Caml 4.01.0. Good!
No Camlp5 installation found. Looking for Camlp4 instead...
You have native-code compilation. Good!
LablGtk2 not found: CoqIde will not be available.
hevea was not found; documentation will not be available
Architecture : win32
Operating system : Windows_NT
Coq VM bytecode link flags : -custom
Coq tools bytecode link flags : -custom
OS dependent libraries : -cclib -lunix
Objective-Caml/Camlp4 version : 4.01.0
Objective-Caml/Camlp4 binaries in : D:/OCaml/bin
Objective-Caml library in : D:\OCaml\lib
Camlp4 library in : +camlp4
Native dynamic link support : true
Documentation : None
CoqIde : no
Web browser : start %s
Coq web site : http://coq.inria.fr/
Local build, no installation...
Access denied - PLUGINS/BTAUTO
Access denied - PLUGINS/CC
Access denied - PLUGINS/DECL_MODE
Access denied - PLUGINS/EXTRACTION
Access denied - PLUGINS/FIRSTORDER
Access denied - PLUGINS/FOURIER
Access denied - PLUGINS/FUNIND
Access denied - PLUGINS/MICROMEGA
Access denied - PLUGINS/NSATZ
Access denied - PLUGINS/OMEGA
Access denied - PLUGINS/QUOTE
Access denied - PLUGINS/ROMEGA
Access denied - PLUGINS/RTAUTO
Access denied - PLUGINS/SETOID_RING
Access denied - PLUGINS/SYNTAX
Access denied - PLUGINS/XML
File not found - (
File not found - -NAME
File not found - .SVN
File not found - -PRUNE
File not found - )
File not found - -O
File not found - (
File not found - -TYPE
File not found - D
File not found - -EXEC
File not found - PRINTF
File not found - \%S\
File not found - {}
File not found - ;
File not found - )
If anything in the above is wrong, please restart './configure'.
*Warning* To compile the system for a new architecture
don't forget to do a 'make clean' before './configure'.
$ make coqlight
File not found - *.mly
File not found - *.mll
File not found - *.mllib
File not found - *.ml4
File not found - *.c
Access denied - .
File not found - (
File not found - {ARCH}
File not found - -O
File not found - -O
File not found - _DARCS
File not found - -O
File not found - -O
File not found - .BZR
File not found - -O
File not found - DEBIAN
File not found - -O
File not found - -O
File not found - _BUILD
File not found - )
File not found - -O
File not found - (
File not found - )
File not found - -PRINT
File not found - *.mli
File not found - .#*v
make --warn-undefined-variable --no-builtin-rules -f Makefile.build "coqlight"
make[1]: Entering directory '/cygdrive/d/Documents/GitHub/HoTT/coq-HoTT'
Makefile.build:842: target '----------' doesn't match the target pattern
Makefile.build:842: target '.GIT' doesn't match the target pattern
Makefile.build:842: target 'MYOCAMLBUILD.ML' doesn't match the target pattern
Makefile.build:842: target 'MYOCAMLBUILD_CONFIG.ML' doesn't match the target pat
tern
Makefile.build:844: target '----------' doesn't match the target pattern
Makefile.build:844: target '.GIT' doesn't match the target pattern
Makefile.build:844: target 'MYOCAMLBUILD.ML' doesn't match the target pattern
Makefile.build:844: target 'MYOCAMLBUILD_CONFIG.ML' doesn't match the target pat
tern
OCAMLDEP lib/loc.ml
OCAMLOPT lib/loc.ml
File "lib/loc.ml", line 71, characters 15-26:
Error: Unbound module Exninfo
Makefile.build:847: recipe for target 'lib/loc.cmx' failed
make[1]: *** [lib/loc.cmx] Error 2
rm lib/loc.ml.d
make[1]: Leaving directory '/cygdrive/d/Documents/GitHub/HoTT/coq-HoTT'
Makefile:138: recipe for target 'coqlight' failed
make: *** [coqlight] Error 2
/cygdrive/d/Documents/GitHub/HoTT /cygdrive/d/Documents/GitHub/HoTT/etc /cygdriv
Thanks,
Jason
- [Coq-Club] Building coq on Windows under cygwin, Jason Gross, 11/06/2013
- Re: [Coq-Club] Building coq on Windows under cygwin, CJ Bell, 11/06/2013
- Re: [Coq-Club] Building coq on Windows under cygwin, Jason Gross, 11/06/2013
- Re: [Coq-Club] Building coq on Windows under cygwin, Jason Gross, 11/12/2013
- Re: [Coq-Club] Building coq on Windows under cygwin, Maxime Dénès, 11/12/2013
