- To: CJ Bell <siegebell AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Building coq on Windows under cygwin
- Date: Mon, 11 Nov 2013 23:19:50 -0500
For any others who face this problem, the solution was to pass the -no-native-compiler option to ./configure.
On Wed, Nov 6, 2013 at 4:18 AM, Jason Gross <jasongross9 AT gmail.com> wrote:
However, now I getcd kernel/byterun/ && \"ocamlmklib" -oc coqrun coq_fix_code.o coq_memory.o coq_values.o coq_interp.oCOQMKTOP -o bin/coqtop.exestrip bin/coqtop.exeCOQC -noinit theories/Init/Notations.vThe input line is too long.Warning:Removed file D:\Documents\GitHub\HoTT\coq-HoTT\theories/Init/Notations.voAnomaly: Library compilation failure. Please report.Makefile.build:479: recipe for target 'theories/Init/Notations.vo' failedmake[1]: *** [theories/Init/Notations.vo] Error 1make[1]: Leaving directory '/cygdrive/D/Documents/GitHub/HoTT/coq-HoTT'Makefile:138: recipe for target 'coqlight' failedmake: *** [coqlight] Error 2/cygdrive/D/Documents/GitHub/HoTT /cygdrive/D/Documents/GitHub/HoTT/etc /cygdriv e/D/Documents/GitHub/HoTTAny ideas?-JasonOn Wed, Nov 6, 2013 at 4:12 AM, Jason Gross <jasongross9 AT gmail.com> wrote:
Thanks. I tried using 8.4 instead of HoTT/coq (and also switching to using administrator) and got told that I was passing the wrong arguments to FIND. Turns out the problem was that `find` was Window's FIND, rather than cygwin's.-JasonOn Wed, Nov 6, 2013 at 1:34 AM, CJ Bell <siegebell AT gmail.com> wrote:
I seem to be able to compile coq just fine with windows 8.1, Cygwin
32bit (setup version 2.830), and coq 8.4pl2. One difference between us
is that my ocaml compiler was installed by Cygwin -- if your ocaml
compiler was compiled for windows, perhaps it expects DOS format
pathnames while configure is giving it posix pathnames.
To get it to work, I only had to fix line 338 of configure (because
checking for version 3.81 or greater of 'make' was rejecting version
4.00). Here is what I changed it to:
if [ "$MAKEVERSIONMAJOR" -ge 4 -o \( "$MAKEVERSIONMAJOR" -eq 3 -a
"$MAKEVERSIONMINOR" -ge 81 \) ]; then
Hope this helps,
-cj
And here are my results:
Coq top directory : C:/Users/cj/Downloads/coq-8.4pl2
$ ./configure -local
You have GNU Make 4.0. Good!
You have Objective-Caml 4.01.0. Good!
No Camlp5 installation found. Looking for Camlp4 instead...
You have native-code compilation. Good!
LablGtk2 not found: CoqIde will not be available.
hevea was not found; documentation will not be available
Architecture : win32Objective-Caml/Camlp4 binaries in : C:/cygwin/bin
Operating system : Windows_NT
Coq VM bytecode link flags : -custom
Coq tools bytecode link flags : -custom
OS dependent libraries : -cclib -lunix
Objective-Caml/Camlp4 version : 4.01.0
Objective-Caml library in : /usr/lib/ocaml
Camlp4 library in : +camlp4Paths for true installation:
Native dynamic link support : true
Documentation : None
CoqIde : no
Web browser : start %s
Coq web site : http://coq.inria.fr/
binaries will be copied in C:/Users/cj/Downloads/coq-8.4pl2/bin
library will be copied in C:/Users/cj/Downloads/coq-8.4pl2
config files will be copied in C:/Users/cj/Downloads/coq-8.4pl2/ide
data files will be copied in C:/Users/cj/Downloads/coq-8.4pl2/ide
man pages will be copied in C:/Users/cj/Downloads/coq-8.4pl2/man
documentation will be copied in C:/Users/cj/Downloads/coq-8.4pl2/doc
emacs mode will be copied in C:/Users/cj/Downloads/coq-8.4pl2/tools/emacs
If anything in the above is wrong, please restart './configure'.don't forget to do a 'make archclean' before './configure'.
*Warning* To compile the system for a new architecture
On Tue, Nov 5, 2013 at 9:47 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
> How do I build coq on windows? When I run ./configure and make, I get
> Objective-Caml/Camlp4 binaries in : D:/OCaml/bin
> Objective-Caml library in : D:\OCaml\lib
> CoqIde : no
> Local build, no installation...
> Access denied - PLUGINS/BTAUTO
> Access denied - PLUGINS/CC
> Access denied - PLUGINS/DECL_MODE
> Access denied - PLUGINS/EXTRACTION
> Access denied - PLUGINS/FIRSTORDER
> Access denied - PLUGINS/FOURIER
> Access denied - PLUGINS/FUNIND
> Access denied - PLUGINS/MICROMEGA
> Access denied - PLUGINS/NSATZ
> Access denied - PLUGINS/OMEGA
> Access denied - PLUGINS/QUOTE
> Access denied - PLUGINS/ROMEGA
> Access denied - PLUGINS/RTAUTO
> Access denied - PLUGINS/SETOID_RING
> Access denied - PLUGINS/SYNTAX
> Access denied - PLUGINS/XML
> File not found - (
> File not found - -NAME
> File not found - .SVN
> File not found - -PRUNE
> File not found - )
> File not found - -O
> File not found - (
> File not found - -TYPE
> File not found - D
> File not found - -EXEC
> File not found - PRINTF
> File not found - \%S\
> File not found - {}
> File not found - ;
> File not found - )
> don't forget to do a 'make clean' before './configure'.
> $ make coqlight
> File not found - *.mly
> File not found - *.mll
> File not found - *.mllib
> File not found - *.ml4
> File not found - *.c
> Access denied - .
> File not found - (
> File not found - {ARCH}
> File not found - -O
> File not found - -O
> File not found - _DARCS
> File not found - -O
> File not found - -O
> File not found - .BZR
> File not found - -O
> File not found - DEBIAN
> File not found - -O
> File not found - -O
> File not found - _BUILD
> File not found - )
> File not found - -O
> File not found - (
> File not found - )
> File not found - -PRINT
> File not found - *.mli
> File not found - .#*v
> make --warn-undefined-variable --no-builtin-rules -f Makefile.build
> "coqlight"
> make[1]: Entering directory '/cygdrive/d/Documents/GitHub/HoTT/coq-HoTT'
> Makefile.build:842: target '----------' doesn't match the target pattern
> Makefile.build:842: target '.GIT' doesn't match the target pattern
> Makefile.build:842: target 'MYOCAMLBUILD.ML' doesn't match the target
> pattern
> Makefile.build:842: target 'MYOCAMLBUILD_CONFIG.ML' doesn't match the target
> pat
> tern
> Makefile.build:844: target '----------' doesn't match the target pattern
> Makefile.build:844: target '.GIT' doesn't match the target pattern
> Makefile.build:844: target 'MYOCAMLBUILD.ML' doesn't match the target
> pattern
> Makefile.build:844: target 'MYOCAMLBUILD_CONFIG.ML' doesn't match the target
> pat
> tern
> OCAMLDEP lib/loc.ml
> OCAMLOPT lib/loc.ml
> File "lib/loc.ml", line 71, characters 15-26:
> Error: Unbound module Exninfo
> Makefile.build:847: recipe for target 'lib/loc.cmx' failed
> make[1]: *** [lib/loc.cmx] Error 2
> rm lib/loc.ml.d
> make[1]: Leaving directory '/cygdrive/d/Documents/GitHub/HoTT/coq-HoTT'
> /cygdrive/d/Documents/GitHub/HoTT /cygdrive/d/Documents/GitHub/HoTT/etc
> /cygdriv
> Thanks,
> Jason
- [Coq-Club] Building coq on Windows under cygwin, Jason Gross, 11/06/2013
- Re: [Coq-Club] Building coq on Windows under cygwin, CJ Bell, 11/06/2013
- Re: [Coq-Club] Building coq on Windows under cygwin, Jason Gross, 11/06/2013
- Re: [Coq-Club] Building coq on Windows under cygwin, Jason Gross, 11/12/2013
- Re: [Coq-Club] Building coq on Windows under cygwin, Maxime Dénès, 11/12/2013
