- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Building coq on Windows under cygwin
- Date: Mon, 11 Nov 2013 23:54:38 -0500
It makes sense. I'll try to investigate the original error (it could be a newline character issue), but probably not before two weeks.
By the way, I made these errors non-fatal on Coq's trunk since r16944. But I guess HoTT-coq is based on an older revision.
Hope it helps and thanks for the report.
Maxime.
On 11/11/2013 11:43 PM, Jason Gross wrote:
I believe the problem is that ocaml complains
The input line is too long.
Warning:
Removed file D:\Documents\GitHub\HoTT\coq-HoTT\theories/Init/Notations.vo
Anomaly: Library compilation failure. Please report.
and fails to create the native code files. If I run make -k instead of make, subsequent files get that error, as well as warnings about missing cmxs files. If this doesn't make sense to you (or if you want me to check this again), I can go get a fresh copy and run ./configure again and let you know whether or not I see any cmxs files. Do you want me to check?
-Jason
On Mon, Nov 11, 2013 at 11:27 PM, Maxime Dénès <mail AT maximedenes.fr <mailto:mail AT maximedenes.fr>> wrote:
Hi Jason,
I saw in your report on the bugtracker that you get some warnings
from the dynlinker, like:
"Dynlink error, cannot find file
D:\coq\theories\Init\NCoq_Init_Datatypes.cmxs in search path"
Do the corresponding .cmxs files exist on your file system or not?
They should have been produced at the same time as the .vo files.
Maxime.
On 11/11/2013 11:19 PM, Jason Gross wrote:
For any others who face this problem, the solution was to pass
the -no-native-compiler option to ./configure.
On Wed, Nov 6, 2013 at 4:18 AM, Jason Gross
<jasongross9 AT gmail.com
<mailto:jasongross9 AT gmail.com>
<mailto:jasongross9 AT gmail.com>>>
wrote:
However, now I get
cd kernel/byterun/ && \
"ocamlmklib" -oc coqrun coq_fix_code.o coq_memory.o
coq_values.o
coq_interp.o
COQMKTOP -o bin/coqtop.exe
strip bin/coqtop.exe
COQC -noinit theories/Init/Notations.v
Warning:
Removed file
Makefile.build:479: recipe for target
'theories/Init/Notations.vo'
failed
make[1]: *** [theories/Init/Notations.vo] Error 1
make[1]: Leaving directory
'/cygdrive/D/Documents/GitHub/HoTT/coq-HoTT'
Makefile:138: recipe for target 'coqlight' failed
make: *** [coqlight] Error 2
/cygdrive/D/Documents/GitHub/HoTT/etc /cygdriv e/D/Documents/GitHub/HoTT
Any ideas?
-Jason
On Wed, Nov 6, 2013 at 4:12 AM, Jason Gross
wrote:
Thanks. I tried using 8.4 instead of HoTT/coq (and also
switching to using administrator) and got told that I was
passing the wrong arguments to FIND. Turns out the
problem
was that `find` was Window's FIND, rather than cygwin's.
-Jason
On Wed, Nov 6, 2013 at 1:34 AM, CJ Bell
<siegebell AT gmail.com
<mailto:siegebell AT gmail.com>
<mailto:siegebell AT gmail.com>>>
wrote:
I seem to be able to compile coq just fine with
windows
8.1, Cygwin
32bit (setup version 2.830), and coq 8.4pl2. One
difference between us
is that my ocaml compiler was installed by Cygwin
-- if
your ocaml
compiler was compiled for windows, perhaps it
expects DOS
format
pathnames while configure is giving it posix
pathnames.
To get it to work, I only had to fix line 338 of
configure
(because
checking for version 3.81 or greater of 'make' was
rejecting version
4.00). Here is what I changed it to:
if [ "$MAKEVERSIONMAJOR" -ge 4 -o \(
"$MAKEVERSIONMAJOR"
-eq 3 -a
"$MAKEVERSIONMINOR" -ge 81 \) ]; then
Hope this helps,
-cj
And here are my results:
$ ./configure -local
You have GNU Make 4.0. Good!
You have Objective-Caml 4.01.0. Good!
No Camlp5 installation found. Looking for Camlp4
instead...
You have native-code compilation. Good!
LablGtk2 not found: CoqIde will not be available.
hevea was not found; documentation will not be
available
Coq top directory :
C:/Users/cj/Downloads/coq-8.4pl2
Architecture : win32
Operating system : Windows_NT
Coq VM bytecode link flags : -custom
Coq tools bytecode link flags : -custom
OS dependent libraries : -cclib -lunix
Objective-Caml/Camlp4 version : 4.01.0
Objective-Caml/Camlp4 binaries in : C:/cygwin/bin
Objective-Caml library in : /usr/lib/ocaml
Camlp4 library in : +camlp4
Native dynamic link support : true
Documentation : None
CoqIde : no
Web browser : start %s
Coq web site :
http://coq.inria.fr/
Paths for true installation:
binaries will be copied in
C:/Users/cj/Downloads/coq-8.4pl2/bin
library will be copied in
config files will be copied in
C:/Users/cj/Downloads/coq-8.4pl2/ide
data files will be copied in
man pages will be copied in
C:/Users/cj/Downloads/coq-8.4pl2/man
documentation will be copied in
C:/Users/cj/Downloads/coq-8.4pl2/doc
emacs mode will be copied in
C:/Users/cj/Downloads/coq-8.4pl2/tools/emacs
If anything in the above is wrong, please restart
'./configure'.
*Warning* To compile the system for a new architecture
don't forget to do a 'make archclean' before
'./configure'.
On Tue, Nov 5, 2013 at 9:47 PM, Jason Gross
wrote:
> How do I build coq on windows? When I run
./configure
and make, I get
instead...
available
> Objective-Caml/Camlp4 binaries in : D:/OCaml/bin
> Objective-Caml library in : D:\OCaml\lib
> CoqIde : no
> Coq web site : http://coq.inria.fr/
> Local build, no installation...
> Access denied - PLUGINS/BTAUTO
> Access denied - PLUGINS/CC
> Access denied - PLUGINS/DECL_MODE
> Access denied - PLUGINS/EXTRACTION
> Access denied - PLUGINS/FIRSTORDER
> Access denied - PLUGINS/FOURIER
> Access denied - PLUGINS/FUNIND
> Access denied - PLUGINS/MICROMEGA
> Access denied - PLUGINS/NSATZ
> Access denied - PLUGINS/OMEGA
> Access denied - PLUGINS/QUOTE
> Access denied - PLUGINS/ROMEGA
> Access denied - PLUGINS/RTAUTO
> Access denied - PLUGINS/SETOID_RING
> Access denied - PLUGINS/SYNTAX
> Access denied - PLUGINS/XML
> File not found - (
> File not found - -NAME
> File not found - .SVN
> File not found - -PRUNE
> File not found - )
> File not found - -O
> File not found - (
> File not found - -TYPE
> File not found - D
> File not found - -EXEC
> File not found - PRINTF
> File not found - \%S\
> File not found - {}
> File not found - ;
> File not found - )
'./configure'.
architecture
> don't forget to do a 'make clean' before
'./configure'.
> $ make coqlight
> File not found - *.mly
> File not found - *.mll
> File not found - *.mllib
> File not found - *.ml4
> File not found - *.c
> Access denied - .
> File not found - (
> File not found - {ARCH}
> File not found - -O
> File not found - -O
> File not found - _DARCS
> File not found - -O
> File not found - -O
> File not found - .BZR
> File not found - -O
> File not found - DEBIAN
> File not found - -O
> File not found - -O
> File not found - _BUILD
> File not found - )
> File not found - -O
> File not found - (
> File not found - )
> File not found - -PRINT
> File not found - *.mli
> File not found - .#*v
> make --warn-undefined-variable --no-builtin-rules -f
Makefile.build
> "coqlight"
> make[1]: Entering directory
'/cygdrive/d/Documents/GitHub/HoTT/coq-HoTT'
> Makefile.build:842: target '----------' doesn't
match
the target pattern
> Makefile.build:842: target '.GIT' doesn't match the
target pattern
match
the target pattern
> Makefile.build:842: target 'MYOCAMLBUILD.ML
<http://MYOCAMLBUILD.ML>
<http://MYOCAMLBUILD.ML>' doesn't match the target
> pattern
match
the target pattern
'MYOCAMLBUILD_CONFIG.ML <http://MYOCAMLBUILD_CONFIG.ML>
<http://MYOCAMLBUILD_CONFIG.ML>' doesn't match the
target
> pat
> tern
> Makefile.build:844: target '----------' doesn't
match
the target pattern
> Makefile.build:844: target '.GIT' doesn't match the
target pattern
match
the target pattern
> Makefile.build:844: target 'MYOCAMLBUILD.ML
> pattern
match
the target pattern
target
> pat
> tern
> OCAMLDEP lib/loc.ml <http://loc.ml> <http://loc.ml>
> OCAMLOPT lib/loc.ml <http://loc.ml> <http://loc.ml>
> File "lib/loc.ml <http://loc.ml>
<http://loc.ml>", line 71, characters
15-26:
> Error: Unbound module Exninfo
> Makefile.build:847: recipe for target
'lib/loc.cmx' failed
> make[1]: *** [lib/loc.cmx] Error 2
> rm lib/loc.ml.d
/cygdrive/d/Documents/GitHub/HoTT/etc
> /cygdriv
> Thanks,
> Jason
- [Coq-Club] Building coq on Windows under cygwin, Jason Gross, 11/06/2013
- Re: [Coq-Club] Building coq on Windows under cygwin, CJ Bell, 11/06/2013
- Re: [Coq-Club] Building coq on Windows under cygwin, Jason Gross, 11/06/2013
- Re: [Coq-Club] Building coq on Windows under cygwin, Jason Gross, 11/12/2013
- Re: [Coq-Club] Building coq on Windows under cygwin, Maxime Dénès, 11/12/2013
