- To: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- Cc: Erik Palmgren <palmgren AT math.su.se>, Coq Club <coq-club AT inria.fr>, Thierry Coquand <Thierry.Coquand AT cse.gu.se>
- Subject: Re: [Coq-Club] Slow checking of destructs
- Date: Sat, 9 Nov 2013 06:40:55 -0500
I agree with Matthieu. I've experienced the same problem, both with the size of the term in general, and with destructing nested sigma types in particular. My category theory library (https://bitbucket.org/JasonGross/catdb, but in the process of being merged into https://github.com/HoTT/HoTT) sped up by a factor of two when I decided to parameterize categories only on the type of objects, rather than on both the type of objects and on the type of morphisms. In my experience, Coq seems to start getting painfully slow when the word count of the goal reaches around half-a-million terms. Additionally, I've run into cases where fully destructing a nested sigma type takes several seconds, while destructing the analogous record takes much less than a second.
Matthieu, do you happen to have any benchmarks or examples on how much your changes actually speed up nested sigmas? (If you're looking for test cases, I think the old version of the issig tactics in types/Record.v in HoTT, and the examples they get applied to there and in my category theory library, would be good test cases. The proof consists of essentially nothing but destructing a nested sigma and a record, and applying reflexivity, and still manages to take several seconds (or more---I think I might be able to dig out a case where the old version of the tactics, which didn't use isequiv_adjointify, took over a minute).)
On Sat, Nov 9, 2013 at 6:26 AM, Matthieu Sozeau <matthieu.sozeau AT gmail.com> wrote:
Dear Erik,
I would suspect that the representation of record projections is the culprit
here. It's easy to check: Set Printing All in the goals where you're doing the
destruct and see if they're reasonably big or not. The type annotations of sigma
projections (and records with parameters) can result in exponentially larger
fully explicit terms, hence longer abstractions/substitutions/retypechecking
used in destruct. Qed/Defined re-typecheck these huge terms.
One solution is to replace sigmas with specific records (with no parameters)
when possible. Another one is to use a more efficient representation of record
projections, without parameters (part of my polyproj branch at
github.com/mattam82/coq.git and soon to be merged with the trunk). If you want
to try it out I can provide guidance.
Cheers,
-- Matthieu
On 8 nov. 2013, at 21:14, Erik Palmgren <palmgren AT math.su.se> wrote:
> Dear Coq users,
> I have been working (together with Olov Wilander) on an implementation of categories of setoids with equality on objects. These are thus not the usual E-categories of setoids. It relies heavily on proof irrelevant families of setoids. Some of the constructions have turned remarkable slow to check in Coq. For instance a 3000+ lines development (see below) took almost two hours to check on a modern laptop. The most time consuming steps are various destructs with patterns and the command Defined. Previously in this list, it has been pointed out that complicated destruct patterns can generate many cases, that may generate huge terms difficult to check. I can not really see that in my example, that so many cases are generated. Perhaps it has instead something to do with the many type dependencies that arise. If someone has a hint as to what makes this example so slow, I would be very grateful.
> The example is
> CategoricalUniverse.v
> in
> http://people.su.se/~epalm/coq/czf_and_setoids/
> (Accompanying paper: czf&setoids_rvsd.pdf in the same directory).
> Erik Palmgren
- [Coq-Club] Slow checking of destructs, Erik Palmgren, 11/08/2013
- Re: [Coq-Club] Slow checking of destructs, Matthieu Sozeau, 11/09/2013
- Re: [Coq-Club] Slow checking of destructs, Jason Gross, 11/09/2013
- Re: [Coq-Club] Slow checking of destructs, Andreas Abel, 11/12/2013
- Re: [Coq-Club] Slow checking of destructs, Erik Palmgren, 11/12/2013
