- To: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>, Thierry Coquand <Thierry.Coquand AT cse.gu.se>
- Subject: Re: [Coq-Club] Slow checking of destructs
- Date: Tue, 12 Nov 2013 08:48:02 +0100
Dear Matthieu,
many thanks for this answer. I am glad that to hear about the ongoing
improvements of the record projections. For now I try to rejig the
sigma-types to fewer parameters. For instance, replacing
Definition doublesigT1 (A B:Set)(R: A -> B -> Set): Set:=
(sigT (fun x: A => (sigT (fun y: B => R x y)))).
by
Definition doublesigT2 (A B:Set)(R: A -> B -> Set): Set:=
(sigT (fun z: (prod A B) => R (fst z) (snd z))).
Best regards
Erik
9 nov 2013 kl. 12:26 skrev Matthieu Sozeau:
> Dear Erik,
> I would suspect that the representation of record projections is the
> culprit
> here. It's easy to check: Set Printing All in the goals where you're doing
> the
> destruct and see if they're reasonably big or not. The type annotations of
> sigma
> projections (and records with parameters) can result in exponentially
> larger
> fully explicit terms, hence longer
> abstractions/substitutions/retypechecking
> used in destruct. Qed/Defined re-typecheck these huge terms.
> One solution is to replace sigmas with specific records (with no
> parameters)
> when possible. Another one is to use a more efficient representation of
> record
> projections, without parameters (part of my polyproj branch at
> github.com/mattam82/coq.git and soon to be merged with the trunk). If you
> want
> to try it out I can provide guidance.
> Cheers,
> -- Matthieu
> On 8 nov. 2013, at 21:14, Erik Palmgren
> <palmgren AT math.su.se>
> wrote:
>> Dear Coq users,
>> I have been working (together with Olov Wilander) on an implementation of
>> categories of setoids with equality on objects. These are thus not the
>> usual E-categories of setoids. It relies heavily on proof irrelevant
>> families of setoids. Some of the constructions have turned remarkable slow
>> to check in Coq. For instance a 3000+ lines development (see below) took
>> almost two hours to check on a modern laptop. The most time consuming
>> steps are various destructs with patterns and the command Defined.
>> Previously in this list, it has been pointed out that complicated destruct
>> patterns can generate many cases, that may generate huge terms difficult
>> to check. I can not really see that in my example, that so many cases are
>> generated. Perhaps it has instead something to do with the many type
>> dependencies that arise. If someone has a hint as to what makes this
>> example so slow, I would be very grateful.
>> The example is
>> CategoricalUniverse.v
>> in
>> http://people.su.se/~epalm/coq/czf_and_setoids/
>> (Accompanying paper: czf&setoids_rvsd.pdf in the same directory).
>> Erik Palmgren
- [Coq-Club] Slow checking of destructs, Erik Palmgren, 11/08/2013
- Re: [Coq-Club] Slow checking of destructs, Matthieu Sozeau, 11/09/2013
- Re: [Coq-Club] Slow checking of destructs, Jason Gross, 11/09/2013
- Re: [Coq-Club] Slow checking of destructs, Andreas Abel, 11/12/2013
- Re: [Coq-Club] Slow checking of destructs, Erik Palmgren, 11/12/2013
