- From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: Erik Palmgren <palmgren AT math.su.se>, Coq Club <coq-club AT inria.fr>, Thierry Coquand <Thierry.Coquand AT cse.gu.se>
- Subject: Re: [Coq-Club] Slow checking of destructs
- Date: Sat, 9 Nov 2013 12:50:19 +0100
Using the fast projections made the compilation time of a 5kloc development
drop from 20 minutes to 15 seconds.
It was full of nested sigmas and parameterized records.
-- Matthieu
On 9 nov. 2013, at 12:40, Jason Gross
wrote:
> I agree with Matthieu. I've experienced the same problem, both with the
> size of the term in general, and with destructing nested sigma types in
> particular. My category theory library
> (https://bitbucket.org/JasonGross/catdb, but in the process of being merged
> into https://github.com/HoTT/HoTT) sped up by a factor of two when I
> decided to parameterize categories only on the type of objects, rather than
> on both the type of objects and on the type of morphisms. In my
> experience, Coq seems to start getting painfully slow when the word count
> of the goal reaches around half-a-million terms. Additionally, I've run
> into cases where fully destructing a nested sigma type takes several
> seconds, while destructing the analogous record takes much less than a
> second.
> Matthieu, do you happen to have any benchmarks or examples on how much your
> changes actually speed up nested sigmas? (If you're looking for test
> cases, I think the old version of the issig tactics in types/Record.v in
> HoTT, and the examples they get applied to there and in my category theory
> library, would be good test cases. The proof consists of essentially
> nothing but destructing a nested sigma and a record, and applying
> reflexivity, and still manages to take several seconds (or more---I think I
> might be able to dig out a case where the old version of the tactics, which
> didn't use isequiv_adjointify, took over a minute).)
> On Sat, Nov 9, 2013 at 6:26 AM, Matthieu Sozeau
> wrote:
> Dear Erik,
> I would suspect that the representation of record projections is the
> culprit
> here. It's easy to check: Set Printing All in the goals where you're doing
> the
> destruct and see if they're reasonably big or not. The type annotations of
> sigma
> projections (and records with parameters) can result in exponentially larger
> fully explicit terms, hence longer abstractions/substitutions/retypechecking
> used in destruct. Qed/Defined re-typecheck these huge terms.
> One solution is to replace sigmas with specific records (with no
> parameters)
> when possible. Another one is to use a more efficient representation of
> record
> projections, without parameters (part of my polyproj branch at
> github.com/mattam82/coq.git and soon to be merged with the trunk). If you
> want
> to try it out I can provide guidance.
> Cheers,
> -- Matthieu
> On 8 nov. 2013, at 21:14, Erik Palmgren
> wrote:
> > Dear Coq users,
> > I have been working (together with Olov Wilander) on an implementation of
> > categories of setoids with equality on objects. These are thus not the
> > usual E-categories of setoids. It relies heavily on proof irrelevant
> > families of setoids. Some of the constructions have turned remarkable
> > slow to check in Coq. For instance a 3000+ lines development (see below)
> > took almost two hours to check on a modern laptop. The most time
> > consuming steps are various destructs with patterns and the command
> > Defined. Previously in this list, it has been pointed out that
> > complicated destruct patterns can generate many cases, that may generate
> > huge terms difficult to check. I can not really see that in my example,
> > that so many cases are generated. Perhaps it has instead something to do
> > with the many type dependencies that arise. If someone has a hint as to
> > what makes this example so slow, I would be very grateful.
> > The example is
> > CategoricalUniverse.v
> > in
> > http://people.su.se/~epalm/coq/czf_and_setoids/
> > (Accompanying paper: czf&setoids_rvsd.pdf in the same directory).
> > Erik Palmgren
- [Coq-Club] Slow checking of destructs, Erik Palmgren, 11/08/2013
- Re: [Coq-Club] Slow checking of destructs, Matthieu Sozeau, 11/09/2013
- Re: [Coq-Club] Slow checking of destructs, Jason Gross, 11/09/2013
- Re: [Coq-Club] Slow checking of destructs, Andreas Abel, 11/12/2013
- Re: [Coq-Club] Slow checking of destructs, Erik Palmgren, 11/12/2013
