- To: Gregory Malecha <gmalecha AT cs.harvard.edu>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Coq Packages, Module Names & Module Resolution
- Date: Thu, 12 Dec 2013 09:19:00 +0100
My opinion on this.
On Thu, Dec 12, 2013 at 5:47 AM, Gregory Malecha
wrote:
> Hello --
> Require Import Bool.
> which previously referred to Coq.Bool.Bool will now refer to this
> ExtLib.Data.Bool. This is obviously a bad thing (since the user doesn't see
> it, spooky action at a distance).
It's even worse in case-insensitive file systems(*). For instance,
recompiling Coq with the Ssreflect library is impossible because
Vector gets confused with vector.
(*) In my opinion they shouldn't exist, but thanks to the two ex-young
entrepreneurs from Silicon Valley, they do!
> I am wondering what the Coq community thinks about this issue. I can think
> of two solutions/work-arounds:
> 1) Should it become best-practice to include files by their absolute names?
Definitively.
> If so, should we special-case the standard library in some way so it does
> not require absolute names?
I prefer not. The less exceptions, the cleaner.
> 2) Should Coq file resolution be changed to not be recursive by default?
Absolutely.
> Are there other solutions? I am happy to work on the code to make whatever
> people think is the best approach a reality. I have already developed a
> small Coq patch that extends vernacular command with [From ... Require ...]
> which would alleviate some of the headache of absolute paths. I've submitted
> a Coq feature request (with the patch) here
> (https://coq.inria.fr/bugs/show_bug.cgi?id=3184).
> I look forward to hearing people's feedback.
> gregory malecha
> http://www.people.fas.harvard.edu/~gmalecha/
- [Coq-Club] Coq Packages, Module Names & Module Resolution, Gregory Malecha, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Beta Ziliani, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Thomas Braibant, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Guillaume Melquiond, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Jason Gross, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Jesper Bengtson, 12/12/2013
