- To: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Coq Packages, Module Names & Module Resolution
- Date: Thu, 12 Dec 2013 10:53:47 -0500
On Thu, Dec 12, 2013 at 4:38 AM, Guillaume Melquiond <guillaume.melquiond AT inria.fr> wrote:
Still, I would add a small exception to the non-recursiveness. If a path happens to point to a directory rather than a file, a file with that name inside the directory should be selected. For instance, to load the Coquelicot library, the user should only have to do "Require Coquelicot" rather than "Require Coquelicot.Coquelicot".
What should the behavior be if there is a module whose absolute path is Foo.Bar.Bar? Should we be able to import it as Foo.Bar? That is, should the above exception only apply to the top level, or should it also apply to subdirectories?
I also think that Coq should separate it's namespacing and it's directory structure, and/or allow mix-in modules (namespaces) that are merged rather than shadowed. (See, e.g., https://coq.inria.fr/bugs/show_bug.cgi?id=3171)
-Jason
- [Coq-Club] Coq Packages, Module Names & Module Resolution, Gregory Malecha, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Beta Ziliani, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Thomas Braibant, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Guillaume Melquiond, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Jason Gross, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Jesper Bengtson, 12/12/2013
