- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq Packages, Module Names & Module Resolution
- Date: Thu, 12 Dec 2013 10:38:50 +0100
On 12/12/2013 05:47, Gregory Malecha wrote:
I am wondering what the Coq community thinks about this issue. I can
think of two solutions/work-arounds:
1) Should it become best-practice to include files by their absolute
names? If so, should we special-case the standard library in some way so
it does not require absolute names?
The standard library is a bit peculiar in that it is a set of libraries. So the "Coq" prefix should not be required. But accessing the inner files of the various libraries should require absolute paths (except for "Coq" again).
2) Should Coq file resolution be changed to not be recursive by default?
I think so. This would alleviate the idiotic naming of some of the libraries I contribute to: all the files of Gappa are prefixed by Gappa_; all the files of Flocq are prefixed by Fcore_, Fcalc_, Fappli_, Fprop_ depending on the subdirectory.
Still, I would add a small exception to the non-recursiveness. If a path happens to point to a directory rather than a file, a file with that name inside the directory should be selected. For instance, to load the Coquelicot library, the user should only have to do "Require Coquelicot" rather than "Require Coquelicot.Coquelicot".
Best regards,
Guillaume
- [Coq-Club] Coq Packages, Module Names & Module Resolution, Gregory Malecha, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Beta Ziliani, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Thomas Braibant, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Guillaume Melquiond, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Jason Gross, 12/12/2013
- Re: [Coq-Club] Coq Packages, Module Names & Module Resolution, Jesper Bengtson, 12/12/2013
