- To: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- Cc: Vladimir Voevodsky <vladimir AT ias.edu>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Export/Import
- Date: Wed, 1 Jan 2014 18:02:49 -0500
No options at all. The files uuu and uu0 were compiled with the command
coqc Generalities/uuu.v
coqc Generalities/uu0.v
from a copy of Foundations/ outside of user-contrib/ and then copied to
/user-contrib/Foundations/Generalities/
Are you sure you did not leave a copy of uuu.vo around somewhere other than
in user-contrib/Foundations/Generalities/uuu.vo ?
Also it is important:
a. To have quotes around all file names.
b. To have two layers i.e. Foundations/Generalities/
V.
On Jan 1, 2014, at 5:51 PM, Guillaume Melquiond wrote:
> On 01/01/2014 23:04, Vladimir Voevodsky wrote:
>> I get an error message:
>> File "./pathnotations.v", line 2, characters 0-21:
>> Error: Cannot find library uuu in loadpath
> I cannot reproduce this bug. The file in the separate directory compiles
> just fine and transitively imports uuu. Could you tell us which options you
> have used to compile the three files? Of particular interest are -I and -R.
> Best regards,
> Guillaume
- [Coq-Club] Export/Import, Vladimir Voevodsky, 01/01/2014
- Re: [Coq-Club] Export/Import, Guillaume Melquiond, 01/01/2014
- Re: [Coq-Club] Export/Import, Vladimir Voevodsky, 01/02/2014
- Re: [Coq-Club] Export/Import, Jason Gross, 01/02/2014
- Message not available
