- To: Vladimir Voevodsky <vladimir AT ias.edu>
- Cc: Guillaume Melquiond <guillaume.melquiond AT inria.fr>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Export/Import
- Date: Wed, 1 Jan 2014 18:14:25 -0500
I cannot even get your uu0 file to compile as given. Why are you using quotes around the names? Can you give a self-contained set of files and set of commands to generate your problem?
jgross@cagnode17:/tmp$ find user-contrib/ -name "*.v"
user-contrib/pathnotations.v
user-contrib/Foundations/Generalities/uu0.v
user-contrib/Foundations/Generalities/uuu.v
jgross@cagnode17:/tmp$ cat user-contrib/Foundations/Generalities/uuu.v
jgross@cagnode17:/tmp$ cat user-contrib/Foundations/Generalities/uu0.v
Require Export "uuu".
jgross@cagnode17:/tmp$ cat user-contrib/pathnotations.v
Require Export "uu0".
jgross@cagnode17:/tmp$ coqc user-contrib/Foundations/Generalities/uuu.v
jgross@cagnode17:/tmp$ coqc user-contrib/Foundations/Generalities/uu0.v
File "./user-contrib/Foundations/Generalities/uu0.v", line 1, characters 0-21:
Error: Can't find file uuu.vo on loadpath
-Jason
On Wed, Jan 1, 2014 at 6:02 PM, Vladimir Voevodsky <vladimir AT ias.edu> wrote:
No options at all. The files uuu and uu0 were compiled with the command
coqc Generalities/uuu.v
coqc Generalities/uu0.v
from a copy of Foundations/ outside of user-contrib/ and then copied to /user-contrib/Foundations/Generalities/
Are you sure you did not leave a copy of uuu.vo around somewhere other than in user-contrib/Foundations/Generalities/uuu.vo ?
Also it is important:
a. To have quotes around all file names.
b. To have two layers i.e. Foundations/Generalities/
V.
On Jan 1, 2014, at 5:51 PM, Guillaume Melquiond wrote:
> On 01/01/2014 23:04, Vladimir Voevodsky wrote:
>> I get an error message:
>> File "./pathnotations.v", line 2, characters 0-21:
>> Error: Cannot find library uuu in loadpath
> I cannot reproduce this bug. The file in the separate directory compiles just fine and transitively imports uuu. Could you tell us which options you have used to compile the three files? Of particular interest are -I and -R.
> Best regards,
> Guillaume
- [Coq-Club] Export/Import, Vladimir Voevodsky, 01/01/2014
- Re: [Coq-Club] Export/Import, Guillaume Melquiond, 01/01/2014
- Re: [Coq-Club] Export/Import, Vladimir Voevodsky, 01/02/2014
- Re: [Coq-Club] Export/Import, Jason Gross, 01/02/2014
- Message not available
