Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- To: Altenkirch Thorsten <psztxa AT exmail.nottingham.ac.uk>, "cody.roux AT andrew.cmu.edu" <cody.roux AT andrew.cmu.edu>, "homotopytypetheory AT googlegroups.com" <homotopytypetheory AT googlegroups.com>
- Cc: "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>, coq-club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Mon, 06 Jan 2014 13:15:52 -0500
The anti-extensionality bug is indeed related to termination. More precisely, it is the subterm relation used by the guard checker which is not defined quite the right way on dependent pattern matching.
It is not too hard to fix (we have a patch), but doing so without ruling out any interesting legitimate example (dealing with recursion on dependently typed data structures) is more challenging.
I am also curious as to whether Agda is impacted. Let's try it :)
Maxime.
On 01/06/2014 12:59 PM, Altenkirch Thorsten wrote:
Which bug was this?
I only saw the one which allowed you to prove anti-extensionality? But
this wasn't related to termination, or?
Thorsten
On 06/01/2014 16:54, "Cody Roux"
wrote:
Nice summary!This message and any attachment are intended solely for the addressee and may
On 01/06/2014 08:49 AM, Altenkirch Thorsten wrote:
Agda enforces termination via a termination checker which is moreThat's a bit scary given that there was an inconsistency found in
flexible but I think less principled than Coq's approach.
the Coq termination checker just a couple of weeks ago :)
BTW, has anyone tried reproducing the bug in Agda?
Cody
contain confidential information. If you have received this message in error,
please send it back to me, and immediately delete it. Please do not use,
copy or disclose the information contained in this message or in any
attachment. Any views or opinions expressed by the author of this email do
not necessarily reflect the views of the University of Nottingham.
This message has been checked for viruses but the contents of an attachment
may still contain software viruses which could damage your computer system,
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
- Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/06/2014
- Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Cody Roux, 01/06/2014
- Re: [Coq-Club] [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Maxime Dénès, 01/06/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Maxime Dénès, 01/06/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Cody Roux, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Vladimir Voevodsky, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/07/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Martin Escardo, 01/07/2014
