coq-club - Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • To: Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: Altenkirch Thorsten <psztxa AT exmail.nottingham.ac.uk>, Maxime Dénès <mail AT maximedenes.fr>, "homotopytypetheory AT googlegroups.com" <homotopytypetheory AT googlegroups.com>, coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se" <agda AT lists.chalmers.se>
  • Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • Date: Mon, 06 Jan 2014 18:45:45 -0500
On 01/06/2014 06:36 PM, Vladimir Voevodsky wrote:
In my opinion only those constructions which can be expressed through
eliminators are trustworthy. There is really no other way to supply
rigorousness to inductive types with pseudo-parameters (or whatever they are
now called) such as Id-types.
This is simply not true, there are whole PhDs dedicated to describing systems which can do better than eliminators. Andreas mentioned sized-types, which are IMO the most mature candidate.
The fact that the implementation is behind the theoretical capabilities is just that, an implementation problem.
Best,
Cody
V.
On Jan 6, 2014, at 6:27 PM, Cody Roux
<cody.roux AT andrew.cmu.edu>
wrote:
The thing about Coq is that it's very disturbing not to have a
Set-theoretic interpretation where Prop is the set of Booleans {True,
False}. Agda of course doesn't have these qualms, but the fact that this
issue appears in Coq without use of anything fancy (impredicativity,
etc) makes me still a bit worried. In particular there should be a
Set-theoretic model for Agda where Empty -> Box and Box -are- equal:
with a sufficiently clever interpretation of inductives, I believe I can
get [[Empty -> Box ]] = [[Box]] = { {} } (where {} is just the empty
set). Can someone with more Agda knowledge try to type the original
problematic term?
Hypothesis Heq : (False -> False) = True.
Fixpoint contradiction (u : True) : False :=
contradiction (
match Heq in (_ = T) return T with
| eq_refl => fun f:False => match f with end
end
On 01/06/2014 06:12 PM, Altenkirch Thorsten wrote:
Hi Maxime,
your postulate seems correct since certainly Empty → Box and Box are
isomorphic and hence equal as a consequence of univalence.
However, I think the definition of loop looks suspicious in the presence
of proof-relevant equality: if we replace rewrite by an explicit use of
subst, loop isn't structural recursive anymore. Hence my diagnosis would
be that rewrite is simply incompatible with univalence.
Cheers,
Thorsten
On 06/01/2014 20:42, "Maxime Dénès"
wrote:
Bingo, Agda seems to have the same problem:
module Termination where
open import Relation.Binary.Core
data Empty : Set where
data Box : Set where
wrap : (Empty → Box) → Box
postulate
iso : (Empty → Box) ≡ Box
loop : Box -> Empty
loop (wrap x) rewrite iso = loop x
gift : Empty → Box
gift ()
bug : Empty
bug = loop (wrap gift)
However, I may be missing something due to my ignorance of Agda. It may
be well known that the axiom I introduced is inconsistent. Forgive me if
it is the case.
Maxime.
On 01/06/2014 01:15 PM, Maxime Dénès wrote:
The anti-extensionality bug is indeed related to termination. More
precisely, it is the subterm relation used by the guard checker which
is not defined quite the right way on dependent pattern matching.
It is not too hard to fix (we have a patch), but doing so without
ruling out any interesting legitimate example (dealing with recursion
on dependently typed data structures) is more challenging.
I am also curious as to whether Agda is impacted. Let's try it :)
Maxime.
On 01/06/2014 12:59 PM, Altenkirch Thorsten wrote:
Which bug was this?
I only saw the one which allowed you to prove anti-extensionality? But
this wasn't related to termination, or?
Thorsten
On 06/01/2014 16:54, "Cody Roux"
wrote:
Nice summary!
On 01/06/2014 08:49 AM, Altenkirch Thorsten wrote:
Agda enforces termination via a termination checker which is more
flexible but I think less principled than Coq's approach.
That's a bit scary given that there was an inconsistency found in
the Coq termination checker just a couple of weeks ago :)
BTW, has anyone tried reproducing the bug in Agda?
Cody
This message and any attachment are intended solely for the addressee
and may contain confidential information. If you have received this
message in error, please send it back to me, and immediately delete
it. Please do not use, copy or disclose the information contained in
this message or in any attachment. Any views or opinions expressed by
the author of this email do not necessarily reflect the views of the
University of Nottingham.
This message has been checked for viruses but the contents of an
may still contain software viruses which could damage your computer
system, you are advised to perform your own checks. Email
communications with the University of Nottingham may be monitored as
permitted by UK legislation.
_______________________________________________
Agda mailing list
Agda AT lists.chalmers.se
https://lists.chalmers.se/mailman/listinfo/agda
