Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- From: Altenkirch Thorsten <psztxa AT exmail.nottingham.ac.uk>
- To: Conor McBride <conor AT strictlypositive.org>
- Cc: coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se list" <agda AT lists.chalmers.se>
- Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Wed, 8 Jan 2014 09:47:52 +0000
- Accept-language: en-US, en-GB
- Acceptlanguage: en-US, en-GB
Hi Conor,
I am sure this must be a stupid question but why is this not covered
by your result that pattern matching can be reduced to eliminators + K?
Cheers,
Thorsten
On 07/01/2014 17:25, "Conor McBride"
wrote:
>Hi Maxime
>On 7 Jan 2014, at 16:56, Maxime Dénès
><mail AT maximedenes.fr>
> wrote:
>> Still, I don't understand why replacing the pattern matching in my
>> example by a call to subst makes the termination check fail.
>A call to subst destroys the "proper subterm" status, whereas
>pattern matching naively preserves it.
>> Maxime.
>>> {-# OPTIONS --without-K #-}
>>> module BadWithoutK where
>>> data Zero : Set where
>>> data WOne : Set where
>>> wrap : (Zero -> WOne) -> WOne
>>> data _<->_ (X : Set) : Set -> Set where
>>> Refl : X <-> X
>>> postulate
>>> myIso : WOne <-> (Zero -> WOne)
>>> moo : WOne -> Zero
>>> noo : (X : Set) -> (WOne <-> X) -> X -> Zero
>>> moo (wrap f) = noo (Zero -> WOne) myIso f
>>> noo .WOne Refl x = moo x
>moo's input is bigger than the third argument in its noo call
>noo's third input is the same as the argument in its moo call
>Size-change termination, how are ye?
>When you do the translation to eliminators, you're obliged to
>show how recursive calls correspond to invocations of the
>inductive hypothesis: here that's just not going to happen.
>Transporting f across myIso does indeed give an element of
>WOne (your Box), but that does not make a nullary inductive
>hypothesis any easier to invoke.
>I'd quite like to see us defining a type theory in which the
>only checking is type checking, then using it as a target for
>elaboration. Eliminators are one candidate, but there are
>others. Sized types are certainly another strong candidate.
>I'm also interested to see whether there are "locally clocked"
>explanations for termination, as there seem to be for
>productivity.
>Interesting times
>Conor
>>> bad : Zero
>>> bad = moo (wrap \ ())
>>>> T.
>>>>> I am also not sure how specific the problem is to univalence. As Cody
>>>>> said, I would expect to find some set-theoretical models where the
>>>>> equality holds. So being able to prove the negation is disturbing.
>>>>> Maxime.
>>>>> On 01/06/2014 07:23 PM, Abhishek Anand wrote:
>>>>>> It is known that UIP is inconsistent with univalence.
>>>>>> Does this typecheck even after disabling UIP(==K axiom?) ?
>>>>>> I might be wrong, but I think that UIP is baked into the typechecker
>>>>>> of Agda.
>>>>>> But, UIP can be disabled somehow?
>>>>>> -- Abhishek
>>>>>> http://www.cs.cornell.edu/~aa755/
>>>>>><http://www.cs.cornell.edu/%7Eaa755/>
>>>>>> On Mon, Jan 6, 2014 at 3:42 PM, Maxime Dénès
>>>>>> <mailto:mail AT maximedenes.fr>>
>>>>>> wrote:
>>>>>> Bingo, Agda seems to have the same problem:
>>>>>> module Termination where
>>>>>> open import Relation.Binary.Core
>>>>>> data Empty : Set where
>>>>>> data Box : Set where
>>>>>> wrap : (Empty → Box) → Box
>>>>>> postulate
>>>>>> iso : (Empty → Box) ≡ Box
>>>>>> loop : Box -> Empty
>>>>>> loop (wrap x) rewrite iso = loop x
>>>>>> gift : Empty → Box
>>>>>> gift ()
>>>>>> bug : Empty
>>>>>> bug = loop (wrap gift)
>>>>>> However, I may be missing something due to my ignorance of Agda.
>>>>>> It may be well known that the axiom I introduced is inconsistent.
>>>>>> Forgive me if it is the case.
>>>>>> Maxime.
>>>>>> On 01/06/2014 01:15 PM, Maxime Dénès wrote:
>>>>>> The anti-extensionality bug is indeed related to termination.
>>>>>> More precisely, it is the subterm relation used by the guard
>>>>>> checker which is not defined quite the right way on dependent
>>>>>> pattern matching.
>>>>>> It is not too hard to fix (we have a patch), but doing so
>>>>>> without ruling out any interesting legitimate example (dealing
>>>>>> with recursion on dependently typed data structures) is more
>>>>>> challenging.
>>>>>> I am also curious as to whether Agda is impacted. Let's try it
>>>>>> Maxime.
>>>>>> On 01/06/2014 12:59 PM, Altenkirch Thorsten wrote:
>>>>>> Which bug was this?
>>>>>> I only saw the one which allowed you to prove
>>>>>> anti-extensionality? But
>>>>>> this wasn't related to termination, or?
>>>>>> Thorsten
>>>>>> On 06/01/2014 16:54, "Cody Roux"
>>>>>> <cody.roux AT andrew.cmu.edu
>>>>>> <mailto:cody.roux AT andrew.cmu.edu>>
>>>>>> wrote:
>>>>>> Nice summary!
>>>>>> On 01/06/2014 08:49 AM, Altenkirch Thorsten wrote:
>>>>>> Agda enforces termination via a termination
>>>>>> checker which is more
>>>>>> flexible but I think less principled than Coq's
>>>>>> approach.
>>>>>> That's a bit scary given that there was an
>>>>>> inconsistency found in
>>>>>> the Coq termination checker just a couple of weeks ago
>>>>>> BTW, has anyone tried reproducing the bug in Agda?
>>>>>> Cody
>>>>>> This message and any attachment are intended solely for
>>>>>> the addressee and may contain confidential information. If
>>>>>> you have received this message in error, please send it
>>>>>> back to me, and immediately delete it. Please do not use,
>>>>>> copy or disclose the information contained in this message
>>>>>> or in any attachment. Any views or opinions expressed by
>>>>>> the author of this email do not necessarily reflect the
>>>>>> views of the University of Nottingham.
>>>>>> This message has been checked for viruses but the contents
>>>>>> of an attachment
>>>>>> may still contain software viruses which could damage your
>>>>>> computer system, you are advised to perform your own
>>>>>> checks. Email communications with the University of
>>>>>> Nottingham may be monitored as permitted by UK
>>>>>>legislation.
>>>>>> _______________________________________________
>>>>>> Agda mailing list
>>>>>> Agda AT lists.chalmers.se
>>>>>> <mailto:Agda AT lists.chalmers.se>
>>>>>> https://lists.chalmers.se/mailman/listinfo/agda
>>>>>> Agda mailing list
>>>>> Agda mailing list
>>>> Agda mailing list
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/08/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Jesper Cockx, 01/08/2014
- Message not available
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Jesper Cockx, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Bruno Barras, 01/08/2014
