Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr, agda AT lists.chalmers.se
- Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
- Date: Thu, 09 Jan 2014 08:41:03 +0100
Le 09/01/2014 01:14, Jesper Cockx a
écrit :
On Wed, Jan 8, 2014 at 9:41 PM, Conor
McBride <conor AT strictlypositive.org>
wrote:
I could never remember the words, but I think it highly unlikely that the paper we wrote back then made any kind of assurance about mutual definitions like moo and noo. If I did, then perhaps I join the good company in error, for which I apologize. I'm sorry, I meant the version of noo I gave
in my previous mail. I'd better call it something else:
woo : (X : Set) -> (WOne <-> X) -> X ->
Zero
woo
.WOne Refl (wrap f) = woo (Zero -> WOne) myIso f
bad : Zero
bad = woo WOne Refl
(wrap \ ())
The
definition of woo falls within the framework of EDPM.
Moreover, it is structurally recursive on its third
argument. It is still incompatible with univalence (as
shown by 'bad'), and it cannot be translated to
eliminators.
that f < wrap f where f amounts to a collections of (no) things, all of which are smaller than (wrap f). NOWHERE is it said that transporting f with respect to an equation on types respects structural ordering relations, and ESPECIALLY IN THE PRESENCE OF UNIVALENCE that is OBVIOUS NONSENSE. Of course, transporting a term along an
equation should not preserve structural ordering. Yet we
should still be able to pattern match on equality proofs
(in the --without-K sense), as long as the definition can
be translated to eliminators.
whole of the recursion. They don't allow you to make up spurious, allegedly smaller, elements of the type by shipping stuff across isomorphisms. I agree, and I think neither should pattern
matching let us do this (at least not with --without-K
enabled). But wasn't the whole point of EDPM to show that
it *is* safe to use pattern matching? What Daniel
and Thomas on the Coq list showed, is that we need an
additional criterion for pattern matching to be safe. My
proposal is to require that the type of the argument on
which the function is structurally recursive, should be
a data type. A different (and probably much more
sophisticated) proposal was given on the Coq list. Do
you have another proposal?
Note that this condition does not seem to appear in Thierry's original paper on pattern-matching in MLTT (1992). However, and sorry for having to cite myself, but I always required such a condition on my works on the termination of rewriting (which generalizes pattern-matching) in the calculus of constructions (with or without sized types). See for instance Def 24 in "Definitions par rewriting in the calculus of constructions" (Math. Structures in Comp. Science 15(1), 2005). Best regards, Frédéric. On the long
term, I think the best way to go would be to actually
perform the translation of pattern matching to
eliminators in Agda, similar to Matthieu's Equations
plugin for Coq. There are just too many subtleties to
pattern matching to get everything correct otherwise,
especially when univalence and higher inductives are
involved.
Jesper
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Altenkirch Thorsten, 01/08/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Matthieu Sozeau, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Jesper Cockx, 01/08/2014
- Message not available
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Jesper Cockx, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Conor McBride, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Frédéric Blanqui, 01/09/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Bruno Barras, 01/08/2014
- Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq, Maxime Dénès, 01/08/2014
