coq-club - Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • From: Conor McBride <conor AT strictlypositive.org>
  • To: Altenkirch Thorsten <psztxa AT exmail.nottingham.ac.uk>
  • Cc: coq-club Club <coq-club AT inria.fr>, "agda AT lists.chalmers.se list" <agda AT lists.chalmers.se>
  • Subject: Re: [Coq-Club] [Agda] Re: [HoTT] newbie questions about homotopy theory & advantage of UF/Coq
  • Date: Wed, 8 Jan 2014 09:50:23 +0000
On 7 Jan 2014, at 22:47, Altenkirch Thorsten
wrote:
> Hi Conor,
> I am sure this must be a stupid question but why is this not covered
> by your result that pattern matching can be reduced to eliminators + K?
The recursive call isn't covered by the inductive hypothesis. The direct
version
gives no account of the inductive hypothesis *at all*, hence the whole mess.
>>>> moo (wrap f) = noo (Zero -> WOne) myIso f
>>>> noo .WOne Refl x = moo x
The recursive call
moo x
is really a recursive call
moo (subst myIso ... f)
but the inductive hypothesis tells us just that we can call moo on outputs of
f.
Bottom line: it's not structurally recursive.
Cheers
Conor
>> moo's input is bigger than the third argument in its noo call
>> noo's third input is the same as the argument in its moo call
>> Size-change termination, how are ye?
>> When you do the translation to eliminators, you're obliged to
>> show how recursive calls correspond to invocations of the
>> inductive hypothesis: here that's just not going to happen.
>> Transporting f across myIso does indeed give an element of
>> WOne (your Box), but that does not make a nullary inductive
>> hypothesis any easier to invoke.
>> I'd quite like to see us defining a type theory in which the
>> only checking is type checking, then using it as a target for
>> elaboration. Eliminators are one candidate, but there are
>> others. Sized types are certainly another strong candidate.
>> I'm also interested to see whether there are "locally clocked"
>> explanations for termination, as there seem to be for
>> productivity.
>> Interesting times
>> Conor
>>>> bad : Zero
>>>> bad = moo (wrap \ ())
>>>>> T.
>>>>>> I am also not sure how specific the problem is to univalence. As Cody
>>>>>> said, I would expect to find some set-theoretical models where the
>>>>>> equality holds. So being able to prove the negation is disturbing.
>>>>>> Maxime.
>>>>>> On 01/06/2014 07:23 PM, Abhishek Anand wrote:
>>>>>>> It is known that UIP is inconsistent with univalence.
>>>>>>> Does this typecheck even after disabling UIP(==K axiom?) ?
>>>>>>> I might be wrong, but I think that UIP is baked into the typechecker
>>>>>>> of Agda.
>>>>>>> But, UIP can be disabled somehow?
>>>>>>> -- Abhishek
>>>>>>> http://www.cs.cornell.edu/~aa755/
>>>>>>> <http://www.cs.cornell.edu/%7Eaa755/>
>>>>>>> On Mon, Jan 6, 2014 at 3:42 PM, Maxime Dénès
>>>>>>> <mail AT maximedenes.fr
>>>>>>> <mailto:mail AT maximedenes.fr>>
>>>>>>> wrote:
>>>>>>> Bingo, Agda seems to have the same problem:
>>>>>>> module Termination where
>>>>>>> open import Relation.Binary.Core
>>>>>>> data Empty : Set where
>>>>>>> data Box : Set where
>>>>>>> wrap : (Empty → Box) → Box
>>>>>>> postulate
>>>>>>> iso : (Empty → Box) ≡ Box
>>>>>>> loop : Box -> Empty
>>>>>>> loop (wrap x) rewrite iso = loop x
>>>>>>> gift : Empty → Box
>>>>>>> gift ()
>>>>>>> bug : Empty
>>>>>>> bug = loop (wrap gift)
>>>>>>> However, I may be missing something due to my ignorance of Agda.
>>>>>>> It may be well known that the axiom I introduced is inconsistent.
>>>>>>> Forgive me if it is the case.
>>>>>>> Maxime.
>>>>>>> On 01/06/2014 01:15 PM, Maxime Dénès wrote:
>>>>>>> The anti-extensionality bug is indeed related to termination.
>>>>>>> More precisely, it is the subterm relation used by the guard
>>>>>>> checker which is not defined quite the right way on dependent
>>>>>>> pattern matching.
>>>>>>> It is not too hard to fix (we have a patch), but doing so
>>>>>>> without ruling out any interesting legitimate example (dealing
>>>>>>> with recursion on dependently typed data structures) is more
>>>>>>> challenging.
>>>>>>> I am also curious as to whether Agda is impacted. Let's try it
>>>>>>> Maxime.
>>>>>>> On 01/06/2014 12:59 PM, Altenkirch Thorsten wrote:
>>>>>>> Which bug was this?
>>>>>>> I only saw the one which allowed you to prove
>>>>>>> anti-extensionality? But
>>>>>>> this wasn't related to termination, or?
>>>>>>> Thorsten
>>>>>>> On 06/01/2014 16:54, "Cody Roux"
>>>>>>> <cody.roux AT andrew.cmu.edu
>>>>>>> <mailto:cody.roux AT andrew.cmu.edu>>
>>>>>>> wrote:
>>>>>>> Nice summary!
>>>>>>> On 01/06/2014 08:49 AM, Altenkirch Thorsten wrote:
>>>>>>> Agda enforces termination via a termination
>>>>>>> checker which is more
>>>>>>> flexible but I think less principled than Coq's
>>>>>>> approach.
>>>>>>> That's a bit scary given that there was an
>>>>>>> inconsistency found in
>>>>>>> the Coq termination checker just a couple of weeks ago
>>>>>>> BTW, has anyone tried reproducing the bug in Agda?
>>>>>>> Cody
>>>>>>> This message and any attachment are intended solely for
>>>>>>> the addressee and may contain confidential information. If
>>>>>>> you have received this message in error, please send it
>>>>>>> back to me, and immediately delete it. Please do not use,
>>>>>>> copy or disclose the information contained in this message
>>>>>>> or in any attachment. Any views or opinions expressed by
>>>>>>> the author of this email do not necessarily reflect the
>>>>>>> views of the University of Nottingham.
>>>>>>> This message has been checked for viruses but the contents
>>>>>>> of an attachment
>>>>>>> may still contain software viruses which could damage your
>>>>>>> computer system, you are advised to perform your own
>>>>>>> checks. Email communications with the University of
>>>>>>> Nottingham may be monitored as permitted by UK
>>>>>>> legislation.
>>>>>>> _______________________________________________
>>>>>>> Agda mailing list
>>>>>>> Agda AT lists.chalmers.se
>>>>>>> <mailto:Agda AT lists.chalmers.se>
>>>>>>> https://lists.chalmers.se/mailman/listinfo/agda
>>>>>>> Agda mailing list
>>>>>> Agda mailing list
>>>>> Agda mailing list
