coq-club - Re: [Coq-Club] Notation for functional relation
  • From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Notation for functional relation
  • Date: Mon, 27 Jan 2014 16:22:52 +0100
On 27/01/2014 16:13, Arnaud Spiwack wrote:
>> Definition extension2 f x y := exists a, exists b, x a -> x b -> f a b
> Unfortunately no.
> In Why3, we display a warning whenever the user writes this kind of
predicate ; it has been helpful to debug some broken specifications
early. It might be worth having the same warning message in Coq.
I'm confused. Apart from the fact that I forgot an obvious lambda (f is
supposed to be of type A->B->(X->Prop)), this definition is a correct
binary extension for the powerset monad. Could you elaborate on the
issue you have with it?
My issue is that this kind of predicate is (almost) always a tautology, which makes it pointless. So I doubt it is what you intended to write in the first place. Didn't you mean the following instead?
Definition extension2 f x y := exists a, exists b, x a /\ x b /\ f a b.
Best regards,
Guillaume
