coq-club - Re: [Coq-Club] Error in Function command
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Error in Function command
  • Date: Fri, 21 Feb 2014 22:26:04 +0100
Hi,
Short answer : the problem comes from the use of -> construction.
Long answer : Can you please fill a bug report at
https://coq.inria.fr/bugs/ so that I can treat the problem as soon as I
come back. I won't be at work next week.
Best regard,
Julien
On Fri, 21 Feb 2014 20:38:57 +0100
Anders Lundstedt
<anders AT anderslundstedt.se>
wrote:
I need to define a recursive function that is not structurally
recursive. With the Function command I get:
"failure in proveterminate
Error: Found a product. Can not treat such a term"
A somewhat minimal example (pastebin: http://pastebin.com/MYdaRG9x):
Require Import Recdef.
Inductive formula :=
| atom : formula
| conn : formula -> formula -> formula.
Fixpoint complexity P : nat := match P with
| atom => 0
| conn P Q => Peano.max (complexity P) (complexity Q) + 1
end.
(* the following definition is OK: *)
Function truth P {measure complexity P} : Prop := match P with
| atom => True
| conn P Q => truth P /\ truth Q
end.
Admitted.
(* the following definition gives the following output:
Function truth' P {measure complexity P} : Prop := match P with
| atom => True
| conn P Q => truth' P -> truth' Q
end.
