- From: Anders Lundstedt <anders AT anderslundstedt.se>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Error in Function command
- Date: Tue, 25 Feb 2014 03:26:29 +0100
On Fri, Feb 21, 2014 at 10:26 PM,
<julien.forest AT ensiie.fr>
wrote:
> Long answer : Can you please fill a bug report at
> https://coq.inria.fr/bugs/ so that I can treat the problem as soon as I
> come back. I won't be at work next week.
I will file a bug report. Is the following also a bug? If so, should I
submit one or two bug reports?
http://pastebin.com/NN8TBD1E
Require Import Recdef.
Inductive formula :=
| atom : formula
| ex : nat -> formula -> formula.
Parameter substitution : formula -> nat -> nat -> formula.
Fixpoint complexity P : nat := match P with
| atom => 0
| ex _ P => complexity P + 1
end.
failure in proveterminate
Error: Found a lambda which body contains a recursive call. Such terms
are not allowed
Function truth P {measure complexity P} : Prop := match P with
| atom => True
| ex n P => exists m, truth (substitution P m n)
end.
- [Coq-Club] Error in Function command, Anders Lundstedt, 02/21/2014
- <Possible follow-up(s)>
- Re: [Coq-Club] Error in Function command, julien . forest, 02/21/2014
- Re: [Coq-Club] Error in Function command, Rui Baptista, 02/22/2014
- Re: [Coq-Club] Error in Function command, Anders Lundstedt, 02/25/2014
- Re: [Coq-Club] Error in Function command, Rui Baptista, 02/25/2014
